Old 05-03-2017, 01:15 AM   #451
Signkutter
Re: 8 lug wheels - what's on YOUR truck?
Originally Posted by FirstOwner69 View Post
I'm not sure of the safety aspect, but there's no way you should need 1.5 inch spacers to gain adequate clearance to use the late model factory caps. Of course the thickness needed will be somewhat variable depending on the thickness of the wheel mounting flange (not sure that's the correct term).
Perhaps davepl can provide further info on what he used with his H2 wheels.
Thanks for the reply. 1.5 inch thick spacers are the thinnest I could find...maybe something to do with structural integrity as the spacers have their own lugs.
I am taking a different approach to the problem now...I am currently in the process of switching out the DANA 60 open diff rear for a 14 bolt Full floater off an 87 1 ton. The hub seems to be a good bit less protrusive and may allow for hub caps and will definitely allow for screw-on center caps....now I'm stuck with 1.5 inch spacers ....
Signkutter is offline   Reply With Quote
Old 05-03-2017, 01:37 AM   #452
mcmlxix
Collector of Projects
mcmlxix's Avatar
I'm pretty sure you have to find center caps from a dually truck to be deep enough to have clearance for H2 wheel....
This site has some measurements...
http://www.hubcaps-wheelcovers.com/c...enter_caps.htm
Rich
1972 K5 Blazer CST Click HERE
Old 05-06-2017, 06:44 AM   #453
Wheel Vintiques 82 Series 16 x 8 with 285/75 Goodyear DuraTracs
Waiting to do hubcaps for now. I have N.O.S. I don't want to run till the truck is cherry. Thinking about making a pair of fronts from some #2s in stainless I have
Old 05-06-2017, 07:33 AM   #454
midniteblues
midniteblues's Avatar
Started loosely assembling my 8ft step bed in anticipation of getting the wack fitting beat fleetside off.
I can raise the floor with the stepper and make it fit on the dump frame easier than a fleet....plus I like the stepper look better on a 4x4.
Picked up another sport comp water temp guage since my old one went south and a small tach.
The kid has this same tach in his truck and its nice, not big and bulky.
I plan on getting the new pto cables hooked up this week I have one on allready but I gotta build brackets for the pto and dump valve.
I've been looking too build some duel's off my manifolds but wow is it gonna be tight with the pto in the way, just might be easier too put the y pipe back on.
Oh and cleaned up a oe front bumper and started putting it on. I'm thinking for now oe bumper and grill guard till I can find a winch.
Also grabbed this square body c member and skid plate this week from the jy gonna try too make it work.
I need to find some lift blocks and u bolts for the rear to level this thing out.
The 205's look good there tim.
Could a swore I was on the wdydtyttt thread...whoops
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-21-2017, 05:40 PM   #455
BlueBullet
BlueBullet's Avatar
'05 ish Dodge 17" rims early 2000's center caps
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 05-21-2017, 07:43 PM   #456
NoStopN
NoStopN's Avatar
I've thought about getting a set of those. I wasn't sure about whether the offset would require spacers. Good thing about Dodge rims is that Dodge still uses Dana axles, so they should fit over the center bore hole.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 07-01-2017, 11:14 AM   #457
NoStopN
NoStopN's Avatar
I came up on these 17" late model factory GMC wheels & went for them.
Old 07-01-2017, 11:20 AM   #458
northerngmc
northerngmc's Avatar
Nice, how did it work with the rear axle stubs? Have you used spacers?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 07-01-2017, 11:52 AM   #459
NoStopN
NoStopN's Avatar
Yep. One & a half inch spacers. If they have their own set of studs, I call them adapters, & these do. I just get nervous about using adapters. I want to change out to 9/16" studs, just for piece of mind.
Old 07-22-2017, 03:04 PM   #460
thetruckrman
Please tell me about the conversion kit needed... I have a 1970 C20 Camper Special with 8-lug wheels. I am considering getting the same Sliverado wheels you show in your photo.
Originally Posted by 8.1PWR View Post
I have 2002 Chevy Silverado wheels with 265/75R16 tires. I purchased the conversion lug nuts to be able to use the center caps. Attachment 1643599
thetruckrman is offline   Reply With Quote
Old 07-22-2017, 10:26 PM   #461
FirstOwner69
FirstOwner69's Avatar
The conversion lug nuts he's referring to are dual thread and allow use of the newer caps on a truck with English measure studs. The size usually needed is 1/2" for the 8 lug trucks with drum brakes before 1971. However, if your truck's front brakes have been converted from the original front drums to discs, you'll probably need 9/16" lug nuts for the front. Of course, all 4 wheels may have been converted from 1/2". All that just boils down to the fact you'll need confirm the size you'll need.
Also, if your axle is a Dana you may need to purchase spacers for the rear wheels. I think 1/2" usually will do it. Then the studs would likely need to be replaced with a longer version.
Here are some eBay listings showing the options:
All 32, 1/2"- http://www.ebay.com/itm/32-LUG-NUTS-...270283?vxp=mtr
All 32, 9/16"- http://www.ebay.com/itm/32-LUG-NUTS-...item3ae5d4da01
He also sells lots of 16 and occasionally has a listing for a mixed lot of 16 of each size.
FirstOwner69 is offline   Reply With Quote
Old 07-23-2017, 04:26 AM   #462
deereboy8r
deereboy8r's Avatar
Here's what I am thinking of running.
[/url]
Not my trucks just an example on trucks
[/url]
Luke ( In God We Trust )
deereboy8r is offline   Reply With Quote
Old 07-28-2017, 10:26 PM   #463
Mayo
Cool Truck
Mayo's Avatar
[/url]
[/url]
Nice, thats my truck you used as an example. I've had those rims on there for 6 years now.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 07-28-2017, 10:31 PM   #464
deereboy8r
deereboy8r's Avatar
Haha hope I didn't bother ya reusing it but yeah it's such a good look. One thing I've noticed with these old trucks you gotta be careful what you run on em or it just won't look right. But when I saw them on your truck and it looked good I knew which ones to get. If you have any other pics I'd like to see some more!
Old 11-03-2017, 12:16 AM   #465
Hotcorner
Hotcorner's Avatar
Attachment 1649299
Attachment 1649300
I know these don't come in white. Did you powdercoat or paint?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 11-04-2017, 09:22 AM   #466
Theboatandcarman
vision wheels just came out with a bunch of new wheels. i would highly recommend checking them out as they have an affordable, yet attractive selection for our 8 lugs!
http://www.visionwheel.com/wheels/5459/vision-off-road
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 11-04-2017, 05:11 PM   #467
JMD
JMD's Avatar
17×7 steels off an '03-'12 Dodge Ram. Not sure how I like them. Might order some beauty rings for a cheap fix until I can afford something shiny.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 11-04-2017, 05:14 PM   #468
52napco
Got to show off my spare tire
52napco is offline   Reply With Quote
Old 11-04-2017, 05:34 PM   #469
Don Quixote
Don Quixote's Avatar
Here is what I'm running, AR23s.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Last edited by Don Quixote; 11-04-2017 at 05:36 PM. Reason: One photo does not apply.
Don Quixote is offline   Reply With Quote
Old 11-04-2017, 06:14 PM   #470
Are those adapters to allow 8 on 170mm wheels to be used in 8 on 6.5" bolt circle?
The powder coat guy said he would just scuff them and powdercoat, so I just scuffed them and painted. I figure all this white coat would be is a coating on top of powder coat, so why not paint? I still have the steel powder coated.
Still trying too hard in the styling department. Give those guys a chill pill and ask them to design a clean simple wheel with smooth rims. Something that doesn't look like it's made out of a bunch of pieces and riveted all together. So funny that Outlaws and Outlaw IIs (copied after Centerlines) were ever so popular till people started disliking the fake rivets. Now it's hard to find wheels that don't have fake rivets and the better companies that made the wheels tat got people away from Outlaw IIs are out of business (Centerline, Weld...). And those are the companies that took us to billet and drop forged quality wheels.
Old 11-04-2017, 07:29 PM   #471
NoStopN
NoStopN's Avatar
Mine are the same bolt pattern as the truck (8x6.5). I'm only using them to use the stock GMC center caps. Otherwise, the wheels fit with no problems.
As for those Vision wheels, I saw one style that had the right design, but I'm not into chrome or black wheels.
Old 11-04-2017, 09:48 PM   #472
Hotcorner
Hotcorner's Avatar
Old 11-04-2017, 10:04 PM   #473
Hotcorner
Hotcorner's Avatar
I’ve got some nice Outlaw IIs in 16.5” with beautiful 33x12.5x16.5 BFGs tires to sell if anyone's interested.
Old 12-30-2017, 05:18 AM   #474
6 2 Carl
6 2 Carl's Avatar
Has anyone run the OEM Alcoa dually wheels that come on the new Dodges? I'm picking up a set for cheap off my local classifieds next week. I'd like to run them on my 1978 K35. Any idea what I'll need to use for lug nuts, and where I can buy them?
I've attached a pic for reference.
1987 R10 Chev Suburban 6.2L Diesel
1984 Frame 1990 Body V20 Chev Suburban 6.2L Diesel Banks Turbo
6 2 Carl is offline   Reply With Quote
Old 12-30-2017, 06:22 AM   #475
Killer Bee
Killer Bee's Avatar
