Old 05-06-2017, 06:42 AM   #1
Zone47
Zone47's Avatar
Question I would like to date my Turbo400 and 12 bolt limited slip ...
.... to see what year they are.
I tried waving flowers at them but they don't seem interested.
(sorry, had to get that out of the way).
I'm pretty sure the truck (68 C10) came with a 6 popper and 3 speed on the column, so the turbo 400 is out of something else and I doubt they would put a 12 bolt into a 6 cylinder truck.
Anyone know where the numbers are on either and how to decode them? Thanks.
Zone47 is offline   Reply With Quote
Old 05-06-2017, 07:06 AM   #2
jessemthompson
Re: I would like to date my Turbo400 and 12 bolt limited slip ...
I don't have the answer for deciding your trans, but I can certainly tell you that the 12 bolt in your truck is more than likely stock. Chevy did put 12 bolts in 6cyl. trucks.
jessemthompson is offline   Reply With Quote
Old 05-06-2017, 07:20 AM   #3
GR8-68
GR8-68's Avatar
Jesse is correct, the 12 bolts was probably one of the most common rear axles in this era of truck including the 6 with 3 You should be able to look the code up for each and be able to know the year.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 05-06-2017, 07:24 AM   #4
halfstep
There is a small aluminum ID on the passenger side of the trans that will get you all the information you want. You'll just have to look up the codes online. Name:  TH400IDTag.jpg
halfstep is offline   Reply With Quote
Old 05-06-2017, 09:28 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Fwiw my 72 Blazer has its original th350 and it does not have an ID tag - the date code is stamped into the oil pan as shown here: http://67-72chevytrucks.com/vboard/s...8&postcount=60
Old 05-06-2017, 10:04 AM   #6
Zone47
Zone47's Avatar
How surprising on the 12 bolt, and how cool is that! It's a tall gear I think. I spun the driveshaft 3 times and the wheels only went around once (wheels going the same direction).
Thanks, I'll climb under today and see what I can find out number wise.
