Closed Thread
Old 05-06-2017, 11:54 AM   #5276
ChaseBBC
ChaseBBC's Avatar
Re: What did you do to your truck today? Chapter II
keep forgetting to do that...sorry
ChaseBBC is offline
Old 05-06-2017, 02:41 PM   #5277
Metaldoc
Metaldoc's Avatar
The plan is working out with some assembly required.
Metaldoc is offline
Old 05-06-2017, 05:38 PM   #5278
mud.man.rj
mud.man.rj's Avatar
Now that's a good tire plan, good one.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 05-06-2017, 07:54 PM   #5279
Boog
laying low
Boog's Avatar
That low bed mount spare tire is a real good idea. I like it. How is it working out underneath? That must be a long bed.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 05-06-2017, 08:22 PM   #5280
Metaldoc
Metaldoc's Avatar
Mudman.
Thanks it's a long bed. I've done a lot of mods to make it work my bed is custom to start with. All the parts are drying now tomorrow it will be installed.
Metaldoc is offline
Old 05-06-2017, 10:11 PM   #5281
jessemthompson
Tinted the windows in preparation of me charging my AC.
jessemthompson is offline
Old 05-07-2017, 09:40 AM   #5282
hdff
hdff's Avatar
took Wanda and the corvette to a small car show . Both won 1st in their class.. Thanks Exxon for the invite
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline
Old 05-07-2017, 11:10 AM   #5283
paul blair
Yellow Blue and You--SMILES all around! The Vette and Wanda look Happy and Proud to be G.M. Thanks for sharing!
paul blair is offline
Old 05-07-2017, 01:48 PM   #5284
Metaldoc
Metaldoc's Avatar
Wheel tub in and it looks great, like it was meant to be there. The bottom of the tub is about an 1 1/2" above the fender side and the tire is an inch below the top.
Metaldoc is offline
Old 05-07-2017, 03:11 PM   #5285
toolboxchev
That is pretty trick. I especially like that you did that with the wood bed and making the custom look almost stock in appearance.
toolboxchev is offline
Old 05-07-2017, 05:08 PM   #5286
Metaldoc
Metaldoc's Avatar
Thanks it was what I was going for. The boards are composite decking.
Metaldoc is offline
Old 05-07-2017, 06:36 PM   #5287
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
3 year old water pump failed. Replaced it with a new one from O-Rielly's. New thermistat and hoses.
I also polished under the hood.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-07-2017, 08:41 PM   #5288
KQQL IT
At the body shop.
KQQL IT's Avatar
Hooked up 12v to the choke.
Installed rebuilt radiator, radiator shop said it is a continuous fin 4 row industrial type.
Will outlast the truck.
KQQL IT is offline
Old 05-09-2017, 10:09 PM   #5289
OregonNed
OregonNed's Avatar
Finished up my oil pressure line tonight. A big shout out to members LockDoc (for the line kit and needed adapter) and TBONE1964 (for an excellent working replacement oil pressure gauge). Everything went together easy and fixed a small oil leak in the process. So nice to get the stock gauges working and and being able to pull out the cheap three gauge under dash panel. Pic is oil gauge at idle.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 05-12-2017, 05:10 AM   #5290
Metaldoc
Metaldoc's Avatar
Finished the hold down for the new spare wheel tub.
Metaldoc is offline
Old 05-12-2017, 09:59 AM   #5291
ghalperin
ghalperin's Avatar
I put my frame on a rotisserie and sprayed it.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 05-12-2017, 06:59 PM   #5292
paul blair
Nice Job--I like Your rotisserie!
Old 05-12-2017, 07:01 PM   #5293
66clow
66clow's Avatar
Installed 2in drop spindles. Now the front is at 5. Gotta put on the c notch to go to 7 on rear. Although I knew the 45 series was too tall I barely got it home lol. Will be looking for some 40 series tires.
66clow is offline
Old 05-12-2017, 07:40 PM   #5294
ghalperin
ghalperin's Avatar
I also used Harbor Freight's disposable spray gun. $9.99 and you don't have to waste time trying to maybe get the epoxy out of it. I removed the air fitting and it went straight in the trash.
Glenn
Old 05-12-2017, 08:06 PM   #5295
paul blair
Attachment 1651454
Good Idea! CHEEP TRICKS material. You are off to a good start!
Old 05-13-2017, 02:02 AM   #5296
Metaldoc
Metaldoc's Avatar
Like it came from factory or some crazy idea.
Metaldoc is offline
Old 05-13-2017, 07:06 AM   #5297
72LB
72LB's Avatar
I've been wondering what to do with my spare, I like it.
Me going to pick up a steering column and getting a start on putting it in.
72LB is offline
Old 05-13-2017, 05:18 PM   #5298
NoStopN
NoStopN's Avatar
I changed the earl & filter in mine. And I did the same for the other 2 in the fleet as well. That's a lot of lubrication to take back to be recycled.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 05-13-2017, 07:42 PM   #5299
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
With Boris' help we got the Steering Wheel off and will start to refurbish it.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline
Old 05-13-2017, 09:03 PM   #5300
paul blair
Cleaned and painted rims yesterday. New 31/10.50 TIRES today!
Closed Thread
