Old 05-07-2017, 10:46 AM   #1
Nhaydt92
Bought an all original truck with one problem
Hey guys bought an all original truck numbers matching 65. Only problem is I bought it from the second owner yesterday because he recently sent a rod through the block. Said it was knocking and he was driving it to the body shop to have it painted and have the engine rebuilt. Now that it's blown he has no interest. I'm looking to put a period correct engine back in it. Does anyone know where I can find a 230 l6 that's good for a rebuild? I'm located in PA. Any help would be appreciated. Want to do a factory restore everything is there and works perfect. Just needs the rust and engine fixed.
Nhaydt92 is offline   Reply With Quote
Old 05-07-2017, 10:53 AM   #2
chevylookin
Re: Bought an all original truck with one problem
This guy is in your area. Keep hitting up CL in your area. Those engines are out there. Just a little hunting and patience and one will turn up. Maybe try for a 292?
https://delaware.craigslist.org/pts/6115266956.html
chevylookin is offline   Reply With Quote
Old 05-07-2017, 10:58 AM   #3
Nhaydt92
Awesome I didn't know if I was gonna be screwed or not. I figured I was just gonna have to ask the right ppl and one will turn up.
Old 05-07-2017, 11:08 AM   #4
factorystock
factorystock's Avatar
'65 Chevy trucks have no permanent markings to what engine was originally installed. Your free to put in a 230 292 283 or 327 ( in some cases). However, it must be year matching. The block code and date code of the engine must be from 1965 in your case. There may be a lot of these engines out there, but finding a 1965 issue will be the most difficult part of the search.
factorystock is offline   Reply With Quote
Old 05-07-2017, 11:15 AM   #5
Nhaydt92
So the vin number isn't actually on the block? Or are you just saying to make it period correct? That would be awesome if I could find a 65. I found a 69. Is there much difference?
Old 05-07-2017, 11:21 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
You would need one for a 1965 If you wanted to put it back to period correct. If you don't care about that and really want to drive it then the 69 will be fine. Heck I have an 89 454 in my truck.
My other truck has the stock tired 283 in it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-07-2017, 11:27 AM   #7
chevylookin
If you want to make it as period correct as possible, a 69 6 cyl engine would be a 250 ci displacement engine and was not around until '66 but it looks just like a 230. No difference at all on the outside. But what factorystock is sayin is that you can put any period motor in these trucks as it was not coded into the vehicles VIN as to what engine the truck came with. You would only find that info on the truck's build sheet and 99% of those were tossed many years ago with 60-66 trucks. They started sticking them on the inside of the glove compartments of these trucks in 67 I believe. So you can put a 230, 250, 283 or 327 from built in 65 and say "yes, that is the original engine to the truck" and no one could doubt you.
Old 05-07-2017, 11:27 AM   #8
padresag
there should be a casting # on the back of the blockon the top rear left just where the bellhousing bolts on. there should also be a number stamped into the boss where the distr. drops into. these numbers will identify your eng. these numbers may cover several years productions. find those numbers and post them back here and someone should help you decipher them.
ron
padresag is offline   Reply With Quote
Old 05-07-2017, 11:42 AM   #9
oem4me
None of your questions can be answered without pictures of the truck.
Ok, maybe that's not true, but lets see it anyway! lol.
Old 05-07-2017, 11:58 AM   #10
Nhaydt92
There ya go. Lol. Originally 503 light green solid color. Original owner repainted it in early 90's
Old 05-07-2017, 12:06 PM   #11
Nhaydt92
ron
I can't find find the one in the back of the block... the one by the distributor reads F0510TF
Old 05-07-2017, 12:20 PM   #12
Nhaydt92
I found a 64 292. Does everything bolt up from the 230 to 292? I'd like to use as many factory parts off my motor as possible.
Old 05-07-2017, 12:46 PM   #13
shp4man
shp4man's Avatar
The motor mounts are different on a 292. My truck was originally a 230, but now has a 250. That is a bolt in, and they made it multi-years, although the older ones are better than the newer ones.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 05-07-2017, 12:56 PM   #14
oem4me
Complete sixes turn up for sale fairly often, and for cheap. More often 230's and 250's, but 292's as well. If you are patient, chances are you may find a motor needing nothing that's ready to drop in and go, and if you are lucky maybe even the right year.
Old 05-07-2017, 12:59 PM   #15
Nhaydt92
So which would I be better with a 69 250 or a 64 292? These are the only ones I can find...
Old 05-07-2017, 01:10 PM   #16
shp4man
shp4man's Avatar
Easier? The 250. More torque? 292. I would buy the engine that is in the best condition.
I don't think the motor mount thing is a big deal, but the 292 has a different head and block, so some of the parts from the 230 won't fit.
Old 05-07-2017, 02:20 PM   #17
vince1
At some point the 250 changed to have an integral head and intake manifold. I believe that wasn't until the seventies though. One mechanic told me they got unbelievable fuel economy. For period correct you would want to avoid that one.
Agreed, get the engine that is in the best condition so you don't have to spend a lot of money on it. Sometimes people take out perfectly good engines to put in V-8's. Back in the eighties a painter in a body shop did that with a slant six which he threw out. I took a compression test and it had 165 right across with cross hatch marks still showing in the cylinders. Kijiji netted me a quick sale of $200 on that one.
vince1 is offline   Reply With Quote
Old 05-07-2017, 03:36 PM   #18
Nhaydt92
You think a wanted post in the classifieds would turn a good 230 up? Maybe ppl are still doing it lol
Old 05-07-2017, 04:38 PM   #19
GMDad
GMDad's Avatar
The flywheel is different on a 292 as well but intake, exhaust manifolds and distributor all interchange. The 1969 250 motor would be a good choice for you will fit right in and you can use the valve cover and air cleaner off your 230 to make it look original.
GMDad is offline   Reply With Quote
Old 05-07-2017, 05:19 PM   #20
nail pounder
nail pounder's Avatar
Keep checking Craigslist, I sold a solid 235 w/3 spd trans w/brand new clutch for $750 when I did my motor swap. Just some food for thought, are you going to be happy w/ a top speed of 55- 60mph? I wasn't. Nothing wrong with a period correct truck, I certainly can appreciate it, but I'm not sure it's adding any value. Think about what you plan to do with this truck, just putt around town on the weekends, home Depot runs etc. OR like me do you plan on driving the wheels off it? Freeways, work, soccer practice, pick up kids from school etc. My 66 has a 350/5spd, my 58 has 350/700r4 and they go anywhere, 80mph no problem. I drive the 66 as my daily driver while I plug away on the 58 build. I'm just saying, if you need to replace the motor, make sure it's what YOU really want for your needs.
nail pounder is offline   Reply With Quote
Old 05-07-2017, 05:25 PM   #21
nail pounder
Oh, and whatever you decide I would recommend running a compression test on any used motor before purchasing. A lot of guys like me doing motor swaps will post ads on Craigslist so you can come see the motor in the vehicle before it's pulled. Good luck and hope you get miles of smiles out of your new to you truck!
Old 05-07-2017, 06:49 PM   #22
nail pounder
http://remanufactured.com/Chevrolet_...er_Engines.htm
Try this?
Old 05-08-2017, 05:35 AM   #23
luvbowties
luvbowties's Avatar
Thumbs up Re: Bought an all original truck with one problem
Don't let the difference in motor mounts scare you off. You can find/buy the correct flywheel and 292 mounts and then have a "bolt-in", as I understand. And man! The increased power and esp. torque would be well worth a bit of extra effort. And none of them are gonna get 20mpg anyway!!!!
s
luvbowties is offline   Reply With Quote
Old 05-08-2017, 10:31 AM   #24
bpmcgee
bpmcgee's Avatar
I'm glad you're deciding to stick with a straight six. I love the small-block sound, but stovebolts have such a unique pattern too!
B
bpmcgee is offline   Reply With Quote
