Tilt column light for gear indicator
I have a 71 with a tilt column, don't know if it is stock to the truck. The light under the gear indicator on the column wasn't working so today I attempted to fix it. Well there wasn't a bulb in it, so off the the parts house to try to find ont that will work. Found one that fit the socket but was to long. But tried it to see it it would work, no luck... does anyone know what size bulb fits and where the power wire is. I would like to get it working, I'm anal about things like that. Any help would be greatly appreciated..
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Oct 2010
Re: Tilt column light for gear indicator
The power wire should be grey and plug in the fuse panel. I think it plugs into "panel light" spade. I don't know the bulb number. It is part of the Turn signal switch.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
#3 | |
![]() Join Date: May 2010
Tilts use #1445 bulbs along with the other 2 parts in the attached picture placed under the gear indicator as hdff stated in post 1. The gray light wire plugs onto the "PNL LTS" spade on the fuse block as I recall. I can confirm that tomorrow. Last edited by FirstOwner69; 04-27-2017 at 02:11 AM. |
#4 | |
#5 | ||
#6 | ||
EDIT: I found this on eBay. http://www.ebay.com/itm/Pebeo-Vitrea...QAAOSw6WdXie7o. It says it should be baked in an oven after application. I bet the heat of the bulb would bake it. Various shades of green are available. I searched for "green glass paint". It looks like Texas Art Supply stores in the Houston area may also sell this paint. Last edited by FirstOwner69; 04-27-2017 at 12:13 PM. |
#7 | |
I looked at some of the green LED lights on eBay also and was thinking the single LED version may be a good choice. There were lots of 10 for under $7.00 or a single for just over $3.00. However, I don't know if they are dimmable or whether they need to be. It seems that bulb is on the circuit that dims with the cluster lights. If so, what would happen when the lights are dimmed?
The gray wire exits the column along with the turn signal wires but does not use the turn signal switch harness connector. Last edited by FirstOwner69; 04-27-2017 at 05:45 PM. |
#9 | |
https://www.superbrightleds.com/more...Specifications
#10 | |
http://www.ebay.com/itm/10x-1-5050-S...ZVu2ZQ&vxp=mtr Last edited by FirstOwner69; 04-27-2017 at 08:30 PM. |
#11 | |
![]() Join Date: Apr 2010
The black wire is a fiber optic line for a non tilt automatic column, Don't know why it would be there if you had a tilt column?
hummm, it's a tilt wheel so I don't know why it's there and not a gray one for the light under the gear indication
#14 | |
#15 | |
#16 |
I have a tilt column also, but the light won't come on. How do you get to the hood and bulb? Do I have to take the wheel off? Or can I get to it by taking the gear indicator off?
#17 |
take the gear indicator off to get to it. I have found out also the wire comes out on the column separately not with the wire harness, it is a gray wire. check and make sure it is there and hooked up
#18 | |
Tonight I'll take the indicator loose. As far as getting the green filter, I think you can get them at Pepboys. |
#19 |
I'm sure the green filters can be found in other places, but I picked up a palette today.
