clutch fork clip
Just got done doing an auto to manual switch in my blazer. After getting the install done , started it up and a cling clang noise. Thought it might of been the flywheel hitting the dust cover. pulled cover off and the clutch fork clip that holds the fork on pivot ball was broken sitting in the bottom of cover. Now, I'm sure the ideal thing is to pull trans out off the engine to fix the problem. dreading doing this again. Anyone ever have success in getting the clip on when its still in the truck? if so, how'd you do it?
Re: clutch fork clip
Make sure you put the clip on the correct way. It doesn't really go on the way it makes sense to me, the clip goes in the hole with the bend of the spring facing outwards.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
