Old 05-08-2017, 02:05 AM   #1
dme922
dme922's Avatar
Brake Pedal Assembly
Is there any difference in a manual and power brake assembly? If so what is it? I switched my truck to power brakes and got the booster bracket from a forum member but the connecting rod is about an inch from the peadal. I can get it connected but it puts my pedal to close to the floor.
dme922 is offline   Reply With Quote
Old 05-08-2017, 06:54 AM   #2
Mr Handy
Mr Handy's Avatar
Re: Brake Pedal Assembly
I don't think there is a difference, the push rod should be adjustable so that you can adjust the pedal location. the power brake pedal sits closer to the firewall because the bore in the master is larger and requires less travel to move the same amount of fluid.
double check the service manual for the proper pedal location I think it says how many inches off the firewall it should be.... I'm sure someone else will chime in as well.
Mr Handy is offline   Reply With Quote
Old 05-08-2017, 06:57 AM   #3
Keith Seymore
Keith Seymore's Avatar
Normally there is a difference in pedal ratio between manual and power brakes.
The '69 and '70 charts that I have do not have that level of detail, but the 71 and 72 charts show around 6:1 for manual and 3.5:1 for power systems.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-08-2017, 07:59 AM   #4
dme922
dme922's Avatar
K
I had the adjustment on the rod out all the way and still lacking about an inch. How far should the brake pedal arm be from the pedal arm bump?
Old 05-08-2017, 09:45 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
1/2" - 1" from the bump stop. Here is an OLD thread that discusses the problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=151551
LockDoc
Leon
Old 05-08-2017, 12:48 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I used the stock manual brake/clutch pedal assembly and just added a booster and the correct push rod. I even used the stock manual drum/drum master cylinder, and have not had any issues. Then I removed the clutch pedal from the assembly when I switched to an automatic.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-08-2017, 09:13 PM   #7
Mike C
Mike C's Avatar
K
What he means is the power brake rod connects up higher on the brake pedal than the manual rod. If you are trying to use the same hole on the pedal, that's wrong.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-08-2017, 09:23 PM   #8
dme922
dme922's Avatar
So were the pedal assemblies the same but the whole was just a bit higher?
Old 05-08-2017, 09:29 PM   #9
dme922
dme922's Avatar
The pedal assembly was for an automatic set up also. It just didnt have power brakes originally.
Old 05-09-2017, 12:14 PM   #10
Hart_Rod
Hart_Rod's Avatar
I think that's backwards. I think the power brake rod should be lower than the manual. Take a look at this:
http://www.mpbrakes.com/techtalk/how...ng-pedal-ratio
Hart_Rod is offline   Reply With Quote
