Old 04-27-2017, 07:56 PM   #901
focusedontheprize
focusedontheprize's Avatar
Re: 53 Surburban "Family Truckster"
Truck looks great Marc. I don't think you are being picky at all - you have that much work into it - why settle for something you don't want?
Awesome.
focusedontheprize is offline   Reply With Quote
Old 04-27-2017, 09:58 PM   #902
youngrodder
youngrodder's Avatar
Awesome.
Thanks man I appreciate it. This weekend I hope to finish creating the small pocket in the frame rails for caliper clearance when aired out...then I have about a weeks worth of grinding welds from the wheel tubs...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 04-28-2017, 07:04 PM   #903
Advanced Design
Advanced Design's Avatar
Originally Posted by youngrodder View Post
Thanks man I appreciate it. This weekend I hope to finished creating the small pocket in the frame rail for caliper clearance when aired out...then I have about a weeks worth of grinding welds from the wheel tubs...
Marc
Grelding.....right?
Advanced Design is offline   Reply With Quote
Old 04-28-2017, 08:12 PM   #904
Flysocal
Following along on this one keep up the good work!
Flysocal is offline   Reply With Quote
Old 04-29-2017, 11:30 PM   #905
youngrodder
Originally Posted by Advanced Design View Post
Grelding.....right?
Yes, Doug did I mention that I bought a new grinder??? I burned mine up a week ago...How did that happen???
Thanks I appreciate it.
Marc
Old 04-30-2017, 12:46 AM   #906
kehstr
kehstr's Avatar
Did I mention that I bought a new grinder??? I burned mine up a week ago...How did that happen
How would that happen?? it's not like it ever got used
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-30-2017, 08:32 PM   #907
youngrodder
Since the weather was pretty crummy this weekend, I did get some work done. I decided that I will go with a 2 piece drive shaft. Picture supplied by Nate. This is pretty common with the C-10 trucks and my Porterbuilt kit is very similar to their C-10 stuff. The benefit to a 2 piece drive shaft is I will not have to cut anymore of my floor (major bonus). I will need a carrier barring bracket from PB. This will be the next care package from Nate.
I finished the small notches for caliper clearance. The notch is not as big as it looks, and there is a lot more frame than what shows in the picture so some worry its safe. I welded pipe inside to notch to reinforce the notch.
I also cleaned up the welds on the underside of the wheel tubs. I coated them with Por15. Next will come the seam sealer and later the raptor bed liner. Pics to come on this later.
Marc
Old 05-01-2017, 06:36 AM   #908
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Are you planning to run with all of the PB parts bolted together, or are you thinking of welding it all together?
ChuckDriver is offline   Reply With Quote
Old 05-01-2017, 02:40 PM   #909
youngrodder
Bolting it together. When all bolted together it will be stronger than a stock frame..
Marc
Old 05-08-2017, 11:03 PM   #910
youngrodder
I have been working on a few small items. One was mocking up the gas filler. I have had this idea for about a year now. One challenge was the angle of the gas filler on the tank. It was slopped back too much. I cut some relief cuts in order to level out the filler then I welded it back closed.
I then located the correct location in the wood floor so I could cut in a hole. I also had to notch the rear flange slightly. I will be replacing the wood, so I want to figure out all my holes and cuts with this rotted wood so I can swap them over to the new wood. I will dress up the tank welds once I pull the tank.
All that is left it to weld a piece of 2" pipe on the bottom of the filler housing so it will match the diameter of the tank filler. I will then join the two with a couple of hose clamps and some 2" rubber hose (rated for gas).
Marc
Old 05-08-2017, 11:05 PM   #911
youngrodder
a few more pics
Marc
Old 05-08-2017, 11:28 PM   #912
oldman3
oldman3's Avatar
Looks good Marc, the way I fill I would have gas everywhere...Jim
oldman3 is offline   Reply With Quote
Old 05-09-2017, 10:48 AM   #913
youngrodder
I'm usually pretty careful. I thought about putting a catch basin under the filer but I like the simplicity of how this looks.
Marc
Old 05-09-2017, 11:15 AM   #914
99 to Life
99 to Life's Avatar
I like that cap.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-09-2017, 04:14 PM   #915
ptc
ptc's Avatar
pretty nice details in everything you do Marc !
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 05-09-2017, 05:34 PM   #916
lower50's
lower50's's Avatar
Where did you get that cap? I really like how you have it sitting on the floor.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-09-2017, 05:40 PM   #917
Dan in Pasadena
Dan in Pasadena's Avatar
Marc, whose filler is that? Do you have a link?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-09-2017, 09:40 PM   #918
youngrodder
Originally Posted by 99 to Life View Post
I like that cap.
Thank you
Thanks, I try to think things through and this idea I have had bouncing around in my head for a while
Here is a link
http://www.ebay.com/itm/231307752485...%3AMEBIDX%3AIT
That one is sold out but there are others. The price is pretty cheap too.
See above.
Marc
Old 05-13-2017, 03:40 PM   #919
RockinKees
RockinKees's Avatar
It's all in the details!!
Nice work!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-13-2017, 10:35 PM   #920
youngrodder
In an effort to put some pressure on Doug to provide some Suburban updates I figured that I would through up a few of my own.
I started with deciding to eliminate the lead joints on both sides of the cowl. I saw where Shannon did the same on some pictures he posted to IG. Pretty straight forward.
Old 06-13-2017, 10:40 PM   #921
youngrodder
The next item was to figure out the rear seat legs. If you recall I shortened the rear seat 3" to fit with my wider tubs and new seat location. The seat had (3) legs but it was easier to eliminate the center leg. I added a cross brace and shortened the legs to clear the notch. I think it turned out pretty decent. Once painted I don't believe many people will notice.
Old 06-13-2017, 10:47 PM   #922
youngrodder
Ok, also on the list is to figure out my 2 piece drive shaft. I had Porterbuilt build me a carrier bearing bracket. I ordered my fancy carrier bearing. All of the C10 guys swear by this bearing. I have the part number if anyone needs it. As soon as I confirm the height of the bracket I need PB will build me a final bracket.
And for good measure, attached is this late 30's Buick that my buddies at Dutchboy's hotrods are building. Most likely we will take this to Columbus GG show in July. I'm looking forward to riding around in this one.
I'm caught up for now. Doug your up..
Marc
Old 06-13-2017, 11:08 PM   #923
mongocanfly
mongocanfly's Avatar
Sweet looking buick..would be fun cruisin round in that..please give the carrier p/n...I'm not sure if I'm going 1 piece or 2 but would be good to put in the info bank..
.was starting to get worried about you and Doug...yall have been quite for way to long
Old 06-13-2017, 11:18 PM   #924
oldman3
oldman3's Avatar
Hey Marc, I knew Doug's story, glad your posting up some stuff and it looking good...Jim
Old 06-13-2017, 11:52 PM   #925
Rods57
Rods57's Avatar
Thats a beefy looking carrier. tank mod is cool too....
Rods57 is offline   Reply With Quote
