#101 |
Re: What did you do to your truck today part IV
Picked up 2 6 lug 15x7 rallies from UNCLE on the 67-72 site. Just a short ride from work. These will tuck in real nice on the front and look better than the 8" rallies I put on after the disc brake upgrade I completed last month.
#102 |
![]() Join Date: Apr 2017
Performed surgery on mine....left me with a lot of questions....I posted a bunch in my build thread but here are some pictures
#103 |
Installed my upper and lower arms. Drop spindles coil tie rods.
#104 |
Got some free plywood that basically matched my "patina" look so i made a temporary bed until my papa and I can rebuild it the right way
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
#105 | |
Moderator
![]() Join Date: Dec 2012
Your upper ball joint hardware is in upside down. The bolts go in from the bottom, nuts on top.
#106 |
Cool cpp installed them thay where ready too go in the box.
#107 |
Installed a new tilt floor shift column. Ordered an led flasher for the turn signals that should arrive tomorrow..
#108 |
Shrank my tank to fit the frame area between the rear axle & the hitch. Started with big square Suburban tank. Cut or 7 inches & rewelded the end cap back on. I'll clean with acid & use Caswell tank sealer to complete.
The new tank measures 26 x 20 x 11, and accepts a TBI fuel pump, should be about 22 gallons. It's 11 inches from the tank to the ground. |
#109 |
Mounted the a new wiper motor in by Newport, it's 2 speed wiper and will be a much needed improvement. Straight in application, still need to run the wires.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 05-08-2017 at 08:18 AM. |
#110 |
I installed the CPP front sway bar on my '66. Boy was that ever worth the money! Truck handles awesome!
#111 |
Is your truck lowered?
1963 Chevrolet C-10 |
#112 |
Painted the white stripe and added the molding trim with 3M double sided tape.
I did not want to drill holes in my truck and the tape works great.
#113 |
Good idea on the tape, but I would be a little hesitant. Because when you drive 88 MPH, things happen......
http://s1299.photobucket.com/user/jb...23904108567829 |
#114 | |
I had to remove a piece that I installed wrong and had to use a heat gun to heat it up then I used a fishing line to pull between the truck and tape to remove that piece of trim and it took a lot of force. Hopefully I won't lose any pieces of trim 😂
#115 |
#116 |
#117 |
Time travel
#118 |
I would like to install those sway bars on my truck as well I have 2 1/2 inch drop spindles in front and bagged it's about a little over 7 inch drop from stock do you think they would work for me?
#119 |
I just installed my sway bar.
#120 |
Started building a radiator shroud for my '61 with a 3 core Champion Radiator and mechanical fan on 350 small block. Using galvanized steel roof flashing and aluminum rivets.
#121 |
Moderator
![]() ![]() Join Date: Aug 2011
Good work outlaw. It amazes me that no one makes actual shrouds, just block off plates with fans on them.
#122 |
I don't have a photo right now but the fan shroud that I got from US Radiator is more than a block off plate. It is an actual shroud.
#123 |
I installed the rebuilt fuel sender, got the tank back in place, and installed the new fuel pump and rebuilt carb.
And I took a video of it running! Video link ![]() |
#124 |
One foot in front of the other
![]() Join Date: Aug 2008
Had installed my mirrors last week. Finished cleaning it up.
#125 |
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
