Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-10-2017, 08:45 AM   #13
Hart_Rod
Hart_Rod's Avatar
Re: How to swap your sealed 7" to LED
Originally Posted by lower50's View Post
It's always a good idea to have fused circuits even if is higher amp than the draw.
Agree 100% on all your circuits being fused. And just in case I wasn't clear, I didn't mean not to use any fuses, I just mean to drop the standard headlight fuse down from 30A to 20A.
Also, are you worried that the rubber seal around the bulb will get hot and melt? I know the heat sink of the bulbs get pretty hot. Here's a picture of mine installed. Thanks again for all of the info!
Here's the lights I purchased:
http://www.ebay.com/itm/322177905990...AIT&rmvSB=true
Hart_Rod is offline   Reply With Quote
7" bulb, convert, how to, led, swap
