idetifying part on 6 cyl. 250
need help identifying this part and the proper name so that i can find one. some type of choke device.
Re: idetifying part on 6 cyl. 250
Divorced choke
this is in my 1969 El Camino , straight 6 250
![]() Join Date: Nov 2006
I don't think the spring under the cover is available anymore
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Feb 2002
I prefer the Manual Choke anyway.
Who Changed This?
![]() Join Date: Jan 2013
looks like matt don't have them
![]() Join Date: Dec 1999
#11 | |
Disconnect the top of the rod from the carb. If you can move the rod up and down easily, you don't need a new choke coil, you need a new mechanic.
The choke coil is a bi-metallic strip of metal that is wound in a coil. It holds/pushes the rod up/down as the engine heats up/cools down. The tin covering the coil is often called a heat-stove to concentrate and retain the heat. The choke coils very, very seldom go bad. Bad ones are almost always the result of some physical abuse by someone.
'67 GMC 2500, 292, 4spd, AC |
The Older Generation
And you adjust it by bending the rod between the coil and the choke lever. LockDoc
![]() Join Date: Jul 2016
Its called a choke thermostat. Divorced choke style.
#15 |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#16 |
Who Changed This?
