Old 05-08-2017, 07:52 PM   #1
Slemmy
What shifter and stick are you running on your T5 swap?
Hello everyone,
I just purchased a rebuilt S10 T5 non-world class to put in my '65 C10 Longbed. I'd like to hear/see what shifters and sticks others have installed who have done this conversion so I can get a starting point of reference.
www.core-shifters.com has come up in my searches on here as a source of good information and products:
https://core-shifters.com/pages/swap-bases
He suggests getting the tranny in the truck without the shifter on, sitting in the truck and finding a "comfortable" shift position for neutral, then measuring that distance to the base of the flange, and then working backwards from there in order to figure out fulcrum height, stick length and shape, etc.
What brand shifter, stick height, shape, etc are you guys running? If you've got pics and references even better!
These forums have been a godsend for me on my journey thus far! Thanks in advance for the help.
Slemmy
"Annie" - '69 Chevy C10 396
"Louise" - '65 Chevy C10 6 Banger
"Victoria" - '65 Mustang Notchback
"Haley" - '62 Mercury Comet S-22
Slemmy is offline   Reply With Quote
Old 05-08-2017, 08:02 PM   #2
chevylookin
Re: What shifter and stick are you running on your T5 swap?
I used the original shifter handle but I had to cut it and weld it 180 degrees around.
chevylookin is offline   Reply With Quote
Old 05-08-2017, 08:10 PM   #3
chevylookin
Here is a dark pictureof mine
Old 05-08-2017, 08:23 PM   #4
Slemmy
Thanks for the pic Chevylookin. How's the comfort at that height?
Slemmy
Old 05-08-2017, 08:42 PM   #5
chevylookin
Im 6'1. It rides fine for me. No leaning but maybe a tiny lil bit of stretching to put it in 5th. My first respinse picis it in 1st. The 2nd pic is the stick in neutral. The 3rd is in second gear. The stock T5 handle is barely bendable even under heat. I did my conversion years ago but i remember i had to cut the handle about 3 inches above the cover plate and I had to beat the ever lovin piss out of it to bend a lil and then i welded it 180 around. Took a lil messin aroynd but i had it where i wanted it in less than an hour. I then put shrink tubing around the handle cuz it was so damn ugly. I used the original Chevy shifter bootand the original t5 shift knob. Works great!
Old 05-08-2017, 08:52 PM   #6
chevylookin
Old 05-08-2017, 09:19 PM   #7
mehoff400
i am using lokar shifter..... dont mind the twin stick on the column
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 05-09-2017, 12:54 AM   #8
Slemmy
Chevylooking thanks for the additional pics. That's definitely something to consider as I am also 6'1". Any idea how long the stick is from the base of the flange to the top of the ball?
Mehoff - That looks to be the 2 bend 16" stick. Am I right? If it is Jocko is running the same 16" Lokar shifter as well and said it works great. No clearance issues in 2nd or 4th?
Thanks for the insight and pics!!
Slemmy
Old 05-09-2017, 01:00 AM   #9
chevylookin
It is 16 1/2" from floor mat to top of shifter knob. Sticks about 9" up from my stock bench seat. I mated it to my hopped up 230. Cut about 4 or 5" from the driveline to my 4:11 gears. I used a 88 Camaro WC with the final .63 OD and then swapped the S-10 tail housing. I can do 75-80 comfortably now. Much nicer.
Old 05-09-2017, 07:38 AM   #10
Slemmy
I'm looking forward to having the same enthusiasm for getting in the highway. The T5 I've got has 3.97 and a .79 OD, so it'll run a bit higher than yours on the highway, but I'm looking forward to it. I'm also mating up to a 230. Great engine.
Old 05-09-2017, 07:44 AM   #11
mehoff400
pic is with it in 2nd
My truck
Old 05-09-2017, 08:53 AM   #12
Slemmy
Mehoff - what base shifter are you using?
Slemmy
Old 05-09-2017, 01:02 PM   #13
Lugnutz65
Lugnutz65's Avatar
Here is my T5 with a salvage yard shifter. I have NOT found this same shift handle on any vendor site.
If you are handy, you can make one.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-09-2017, 01:07 PM   #14
Lugnutz65
Lugnutz65's Avatar
More
Old 05-10-2017, 08:51 PM   #15
mehoff400
stock... currently i have a short throw shifter. but pic was with stock base shifter.
My truck
Old 05-10-2017, 10:45 PM   #16
Mackie
Mackie's Avatar
Using the S10 shifter that came with the NWC I had at first then heated and bent the shifter stub to clear the bench seat and move closer to my right knee when I swapped in a WC. Also made my own short throw with a 3/4" block and moved the pivot point a like amount. Now has a plain white knob.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 05-10-2017, 10:48 PM   #17
chevylookin
Thumbs up Re: What shifter and stick are you running on your T5 swap?
That looks good, clean and simple Mackie. Now you guys have me wanting to redo my T5 shifter. To-do-list just got longer!!
Old 05-15-2017, 08:09 PM   #18
Slemmy
Ended up buying a mustang shifter and the Lokar 16" stick. Got a shift boot retainer and boot for an MGB. Should all be going in tomorrow. I'll post some pics as soon as I get it all together.
Slemmy
Old 05-16-2017, 04:21 PM   #19
Wrenchbender Ret
I didn't think a Mustang shifter would fit a S-10 or Camero T-5 trans.
Wrenchbender Ret is offline   Reply With Quote
Old 05-16-2017, 11:41 PM   #20
hop sing
hop sing's Avatar
Nice set up if you don't mind me asking what is ur seat out of ? looks like a good fit thx Hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
shifter suggestions, transmission change
