Old 05-10-2017, 08:21 PM   #1
Coley
Coley's Avatar
Smile Steering Box- interchange?
Does anyone know if a (quick ratio) steering box out of a 73' or 74' GM pickup will fit in the 69-72's without issue?
I think these '73/'74 units were still (pre-metric) imperial fittings, etc but to my understanding they had an option for a little faster ratio which would be a nice upgrade?
I'm talking 2wd 1/2 ton to 2wd 1/2 ton interchange
Anything to watch for or problems? steering knuckle fit etc or?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-10-2017, 09:51 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Steering Box- interchange?
Yes, the box will interchange without mods.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-11-2017, 09:48 AM   #3
72bowtiestepper
Thanks Tx Firefighter !....I will be doing the same swap on my 72 C-10...good info.
72bowtiestepper is offline   Reply With Quote
Old 05-11-2017, 09:50 AM   #4
Hart_Rod
Hart_Rod's Avatar
What's the difference in the 2 ratios? What would be a good aftermarket box to purchase? TIA.
Hart_Rod is offline   Reply With Quote
Old 05-11-2017, 08:16 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
IIRC the later boxes are actually a Variable Ratio and are 3 1/2 turns lock to lock. The originals are 4 1/2 turns LTL and are not variable.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-11-2017, 09:43 PM   #6
davischevy
davischevy's Avatar
I've always just gone to my favorite auto parts store and asked for a box for a 1978 model.
In years past the input shaft was the same as the 67-72 and I could use the old rag joint. The last three I did required a new rag joint for the smaller diameter input shaft.
As old as these original joints are, it's not a bad idea to change it anyway.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 05-11-2017, 10:17 PM   #7
Onebean
Does that variable ratio drive noticeably different that the stock unit? I'm considering replacing my box with something better/faster. I was looking at this LARES 11074 on Rock Auto. I haven't done any research on it yet though. Pretty spend at $333.
Onebean
Onebean is offline   Reply With Quote
Old 05-11-2017, 10:37 PM   #8
Coley
Coley's Avatar
Smile Re: Steering Box- interchange?
1978?...were the fittings still imperial?...or did you have to add imperial to metric adapters to 'plumb' it in to the power steering lines, etc.
Maybe that was the final year for the imperial stuff....?
Coley
2000 Dodge Ram 1500
Old 05-12-2017, 12:08 AM   #9
57taskforce
All about them K’s
57taskforce's Avatar
Coley
I don't think gm went to metric until the early 80s. 1981 maybe???
Tyler
Old 05-12-2017, 12:38 AM   #10
lux
I got the Red Head quick ratio gear. I read really good reviews. Ive had it on my truck for about 5 months now and am very happy so far, they are a bit pricey $349.95 but after all the reviews I read I believe its a very high quality unit.
http://www.classicheartbeat.com/67-72_chassis_2.htm
lux is offline   Reply With Quote
Old 05-12-2017, 11:38 AM   #11
67 chevelle
67 chevelle's Avatar
I have a 1978 power steering box in my 68 c10 , replaced the old [leaking everywhere ]ram assist that was on it stock , love the feel of it now , changed the handling drastically in a good way .
I think I counted 12 fittings on the ram assist , most of them leaked .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-12-2017, 04:01 PM   #12
Hart_Rod
Hart_Rod's Avatar
Do you have a part number? is that price with our without an exchanage? TIA
Old 05-12-2017, 05:15 PM   #13
PanelDeland
Onebean
It's a more "positive" feel with more feedback but I personally find it much better. The originals just always feel mushy to me since they require no effort to turn except of a long way to turn.
If you know someone with a square body, feel their assist and you'll notice the difference.
Old 05-12-2017, 05:19 PM   #14
PanelDeland
Coley
I used a 81^ box on mine and a PS pump and brackets from a 74 or so Nova. The fittings didn't work with each other so I9 swapped the one from the back of the 81^ pump into the Nova Pump and used the factory hoses. I'll have some that fit better made but what I have works really good, they're just too long. That fitting in the back of the pump is the only real change needed to be able to use the later hoses.
Old 05-12-2017, 05:37 PM   #15
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
So is bottom line here the fact that a steering box from a 1978 C10 is a bolt in?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-12-2017, 06:51 PM   #16
davischevy
davischevy's Avatar
Yes. May require a new rag joint. Around $135 US plus core at most parts stores.
other Larry
Old 05-12-2017, 10:32 PM   #17
Onebean
Thanks of the reply. I'll look into a square body box.
Old 05-13-2017, 06:24 PM   #18
slikside
slikside's Avatar
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 05-14-2017, 12:06 PM   #19
Ruscal
Are any members using a 12:1 box on a daily driver? I would like to speed up my ratio, but wonder if 14:1 is quick enough for occasional autocross on a short bed truck? Would the 12:1 be too busy on the freeway?
Russ
RC
Ruscal is offline   Reply With Quote
Old 05-14-2017, 08:29 PM   #20
sackracing
sackracing's Avatar
Subscribed
sackracing is offline   Reply With Quote
