05-11-2017, 08:36 AM | #1 |
1965 4 wheel disc brakes
I wanna see if you guys have ever heard anything like the situation I am currently having. Ill try and sum it up. My truck has front and rear disc brakes with new master/booster and disc/disc prop valve. I have no brake fluid leaks! My truck has a perfect brake pedal until I hook up my vacuum to my brake booster. When I plug in my vacuum my pedal goes all the way to the floor with slight resistance. However Ive been driving the truck with it unhooked and it does fine. It all started after i replaced booster/master and installed rear disc. Anyone ever seen such??
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
05-11-2017, 11:07 AM | #2 |
Never Ending Projects
Re: 1965 4 wheel disc brakes
Likely a bad booster. My buddy has done his '72 Nova and '68 C10 with CPP boosters and in both cases, they were bad right out of the box. Had them replaced under warranty and the replacements worked perfect.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-11-2017, 11:47 AM | #3 |
My booster is a MBM booster off ebay. But they already sent me another one and it changed nothing. Does changing booster size (diameter) matter any? I have a smaller booster than I did before.
05-11-2017, 02:00 PM | #4 |
I would say there is still some air. The added brake line pressure from the booster is able to better compress it over the manual brakes.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-11-2017, 10:25 PM | #5 |
I have bled probably 3 pints of brake fluid through. I was getting solid fluid through it at the end. But Idk maybe I should try it again. It's crazy though because the pedals fine until I hook booster up. Then goes to the floor.
05-12-2017, 06:34 AM | #6 |
So there are two ways a master cylinder will go to the floor, air or its bad.
Jimmy
05-12-2017, 07:17 AM | #7 |
Could my bore size being too big or too small have any effect? I guess I need to get another master cylinder.
05-14-2017, 10:41 PM | #8 |
Have you tried adjusting the push rod on your booster?
Here's a link to the CPP trouble shooting guide. There's a tool they recommend for checking the length http://www.classicperform.com/TechBo...ot.htm#pushrod |
05-15-2017, 07:40 AM | #9 | |
05-16-2017, 12:29 PM | #10 |
Does brake booster size have any affect? My old booster was HUGE compared to this 8 or 9" I have now..
05-16-2017, 06:21 PM | #11 | |
Here's a helpful article about Booster/Master cylinder combos: http://www.mpbrakes.com/techtalk/boo...ur-classic-car |
05-17-2017, 07:25 AM | #12 | |
05-17-2017, 09:24 AM | #13 |
I would just go to your local parts store and buy a master cylinder for a late 60s or early 70s Corvette with power brakes. Those years of Corvette have 4 wheel disc and a 1 1/8 master. Only about $35 but I think they are shallow so your booster pin may need to be changed
05-17-2017, 09:47 AM | #14 | |
05-17-2017, 10:18 AM | #15 |
Don't forget to bench bleed the master before installing.
I hope this helps, good luck. |
05-17-2017, 08:11 PM | #16 |
Thanks man, will do!
