Old 05-17-2017, 09:08 PM   #1
Zone47
Zone47's Avatar
Angry Smoke and flames from under the dash!
Ok, at least smoke..... the flames weren't too far behind. Holy crap I was freaking out.
Luckily I was able to rip the hot lead off the battery before the flames set in but somehow the key switch decided it was time to short out. You'd think a fuse would blow somewhere.
I pulled the switch out and the connector apart and the purple solenoid wire got melty. I'm not sure how to get the switch further apart but am afraid it is one of those things that will come flying apart and I'll never get it back together.
Can you buy replacement switches (in dash for a 67 or 68)?
Soo... ACC is on top, Solenoid is underneath it, Batt on the right, ground 1 and 2 on the bottom.... and IGN on the left.
Zone47 is offline   Reply With Quote
Old 05-17-2017, 09:13 PM   #2
terry b
terry b's Avatar
Re: Smoke and flames from under the dash!
Man that is some Scarry stuff. Could have happened anytime. Thank God you were there to take charge.
terry b is offline   Reply With Quote
Old 05-17-2017, 09:14 PM   #3
HO455
HO455's Avatar
Wow!
Were you starting the truck when this occurred?
RIP Bob Parks.
Old 05-17-2017, 09:19 PM   #4
Zone47
Zone47's Avatar
Wow!
Yeah, I started it to back it out of the garage.
The first clue was that the starter wouldn't release even after the engine fired up. I turned it off and tried again, it did the same thing. I tried one more time and then turned the key off and back on real quick which disengaged the starter but let the engine keep running. Then I backed it out and saw all this smoke happening.
So either way I had problems but usually a fire burning the truck up is a bigger problem.
Old 05-17-2017, 09:32 PM   #5
HO455
HO455's Avatar
I would check the switch with a ohm meter and if the start contact is fused I would replace the switch. I have been down the tear it apart and fix it road. It can be done. It is a pain. Parts will want to fly away. And in the end the contacts are damaged and once cleaned up with a file they may not make good contact with each other then you have the opposite problem. I would also check the neutral safety switch, the firewall connectors, and the connection at the solenoid for damage too. If the switch checks out with the meter then you may have a starter issue.
Yes! Burning wires under the dash are a big issue. At least you weren't crossing the traps at 105+ in the dark with no lights except the red glow shining through the smoke from under the dash.
RIP Bob Parks.
Old 05-17-2017, 09:50 PM   #6
Zone47
Zone47's Avatar
Thanks, I'll have to dig into it more tomorrow .... I imagine there new switches available, I'm just not sure if they will connect up properly. I might as well dig into the old one first and see what went wrong.
I'd like to find a schematic of the wiring on this truck to see what is supposed to be fused. Things tend to sometimes change over 50 years.
Yeah, it could have been a bad scene.... I mean anywhere down the road it could have happened and I don't normally carry any pressurized fire retardant with me.
Originally Posted by firedemon View Post
when you do get it fixed you can add a fusable link so that doesn't hopefully happen again . the purple wire is 12 gauge so use a 6 inch piece of 16 gauge wire at the starter solenoid to the purple wire .
Thank you, good idea!
Old 05-17-2017, 10:37 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Great idea if you ask me. Congratulations OP, you saved your truck's life.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-17-2017, 11:11 PM   #8
franken
Yup.
Fusible link from the battery to the low current side. Been there, fried that...
Old 05-18-2017, 09:26 AM   #9
midniteblues
midniteblues's Avatar
And quite possibly the garage too.
Fusible links are a good idea.
I bet your thinking you need a fire extinguisher now...do it cheap insurance.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-18-2017, 09:33 AM   #10
67 chevelle
67 chevelle's Avatar
http://www.ebay.com/itm/Ignition-Sta...pYo1X1&vxp=mtr
pretty cheap to get a new one , for a 72
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-18-2017, 10:00 AM   #11
weq92f
weq92f's Avatar
Originally Posted by midniteblues View Post
...I bet your thinking you need a fire extinguisher now ...
Very good idea! One I'm doing today after a bit of a fire scare myself yesterday ( left a grease towel under the hood making contact with the header ).
I'm going to eventually have 3: garage, truck and kitchen.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-18-2017, 10:11 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Rockauto shows six different brands of a 68 model c10 switch in stock from cheapies all the way up to Ac Delco and Goodmark.
If you like Ac Delco, they have ACDELCO D1406A in stock for 20 dollars.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-18-2017, 09:40 PM   #13
Zone47
Zone47's Avatar
Thumbs up Re: Smoke and flames from under the dash!
Wow! Thanks, that's exactly what I have!!!
I'll check those too, thanks!
Old 05-18-2017, 10:15 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Lucky for quick action and disconnecting the battery! I'd personally go for an inline fuse, since it is less of a pain to replace if this ever happens again.
Looks like you should change your handle here to FIREBALL.
~Steven
Simi Valley, CA
