Old 05-18-2017, 01:29 PM   #1
61Chevy454
Is there a dual resevoir disc brake master cylinder that will hook up in a 61?
Hey guys, so I have a 61 K20. It has GM 10 bolt axles front and rear, the fronts have discs, the rears have drums. Now I'm kind of sketched out by the single reservoir master cylinder in it, as if I lose a wheel cylinder, none of my brakes will work at all. I'm pondering in the future, possibly putting in power brakes with a booster from Captain Fab, and swapping discs in the back. I figure it would also be a good time to change the master cylinder to something more modern. Do any of you have any idea of what might fit in terms of dual reservoir disc brake master cylinders?
61Chevy454 is offline   Reply With Quote
Old 05-18-2017, 02:55 PM   #2
blown240
blown240's Avatar
Re: Is there a dual resevoir disc brake master cylinder that will hook up in a 61?
IM pretty sure any newer GM master will bolt to a GM booster. And by newer, anything from the 70s and up I think....
Here is my setup...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 05-18-2017, 04:32 PM   #3
forestb
forestb's Avatar
I would ask Captain Fab which boosters will work with his bracket. You have to make sure you get a booster with a rod that will attach to your brake peddle otherwise you will have to do some modifications to the rod.
forestb is offline   Reply With Quote
Old 05-19-2017, 12:04 AM   #4
Captainfab
60-66 Nut
If you are going with 4 wheel disc brakes, you will want a '77-'81 Corvette master cylinder. You will also need either a fixed disc/disc proportioning valve or an adjustable valve in the rear line.
