Center link orientation please...
After installation of the front suspension on a friends '68 I have concerns with the left side inner tie rod trying to rub the lower lip of the cross member. Just wanting to make sure everything is positioned correctly being I wasn't the one to take everything off for restoration...Thanks Ed
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
![]() Join Date: Mar 2003
Re: Center link orientation please...
When the truck is off the stands and the tires on the ground with weight on them, it should clear just fine
That's great news, thank you for your reply...Ed
![]() Join Date: Jul 2016
Center link position is correct. Looks great bud
Are you running an upper bump stop? I see you have a lower but cant tell on the upper.
Also, is your pitman arm torqued in these pictures? It looks like there are alot of splines above the arm. |
#6 | |
1.yes 2.no 3.yes there were These pics were taken before final torqueing, thanks for asking... Thanks Randy for your response also...
