they did make some of our factory style wheels in 15X7 right? what were they on, vans or something?
and do they have the same backspace as a 15x8, just an inch taken off the outside?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
I don't know if there were factory 15 X7 rally wheels, but the vans had 15 x 6.5. The pair I have had about 1/4" less backspacing than my 15 X8 wheels. I used them on the front after I installed drop spindles. I didn't have to grind as much from the lower a-arm lip.
any body know if there were 15x7's? 15X6.5 would probly work for me too if i can find 2 of them
I found a set of 2 15X7's on the side of the road on my way home. They had some ****ty old tires that I had to dismount but I hope to try them soon. I'll post some pics when I get em mounted. The 15X10's I bought look wicked with the 27.5X12 slicks I bought on ebay.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
Garage Queen Material
on the decal on my drivers door, it said my truck originally came with 15x7's
91 SWB 383
hey low84. if u need a set let me know . that what i use to have my truck painted and don;t need them any more .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
Mudslides 'r my specialty
What vehicles came with the 15 X 10 rallys in the 5X5 bolt pattern?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
#8 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Basically 15x7 were standard, 15x8 were optional. From what I remember, Burbs came standard with 15x8's. 15x10 are aftermarket. Usually you can find 15x7's on non-Silverado or early model pickups. They will be marked on the rim lip.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#10 | |
Van ralleys are 6.5" wide.
#12 | |
i'll be back up in dallas in may, i'll get with you then. truck should be running in a couple of weeks ![]()
91 SWB 383
cool u can have all 4 of them . they have somewhat of good tires . i'll hold them
thanks man!
#15 |
91 SWB 383
u can go to the pic of my truck and see them
