Old 05-20-2017, 09:33 PM   #1
rockyrivermark
1970 c10 350 4 bolt main?
New to me truck about 4 months ago. On the tail end of a restoration
I don't see myself pullinf the oil pan anytime soon and trying to find out if my 350 is 4 bolt main.
Being work Trucks where they all 4 bolt?
Just curious.
Mark
rockyrivermark is offline   Reply With Quote
Old 05-20-2017, 10:21 PM   #2
tdangle
tdangle's Avatar
Re: 1970 c10 350 4 bolt main?
My 70 C20 is a 4 bolt main. Original engine, rebuilt once
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-22-2017, 01:18 PM   #3
BILT4ME
Just curious.
Mark
Look for the casting number on the top of the block BEHIND the left head, right next to the firewall. If the number ends in 0010, then, yes, it's a 4-bolt main.
If you want to rebuild, then do it. We just went with a 350 crate engine from Radley Motors in VA. MUCH cheaper than trying to rebuild.
Do a search here for Radley and look it up that way.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 05-22-2017, 03:07 PM   #4
geezer#99
geezer#99's Avatar
Not all the 010 blocks were 4 bolts.
327's could be 010 blocks and where definetly not 4 bolt.
You need the suffix code from the front pad to know for sure
geezer#99 is online now   Reply With Quote
Old 05-22-2017, 03:42 PM   #5
kwmech
Even then that is not positive. The only way to tell positively is to visually see the main caps, which of course means pulling the pan
Old 05-22-2017, 05:05 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I agree with this...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-22-2017, 05:52 PM   #7
truckster
truckster's Avatar
And unless you're wanting to brag to someone who doesn't really know the difference it's not going to matter. Until you get into the 400+ hp range the 2 bolt is perfectly adequate. And if you're going to really build a motor, you probably want splayed main bolts.
I've been inside a lot of motors, and I've never seen a main bearing cap fail in a stock motor, 2 or 4 bolt. The rods are likely to go long before the mains do.
truckster is offline   Reply With Quote
Old 05-22-2017, 06:17 PM   #8
Coley
Coley's Avatar
Smile Re: 1970 c10 350 4 bolt main?
Fully agree.
To my understanding they put both 2 bolt and 4 bolt blocks in the trucks.
One interesting piece of info that I received years ago....was that the 4 bolt main engines were easily identified by a 1/8" Npt plug, facing upwards at a minor angle, in the front casting of the block....just below the intake manifold join and just left (passenger side) off centre close to the upper water pump area.
Supposedly this was used to either pre-lubricate or test something connected with that 4 bolt option. (?)
I don't know if that is fact....but the truck engines that I have seen that are 4 bolt, have had that 1/8" npt plug.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-22-2017, 07:31 PM   #9
kwmech
Originally Posted by Coley View Post
Fully agree.
All Good
Coley
Interesting tidbit, hafta check that out
