water leak in cab, under carpet ?
i notice water under my carpet after i go thru car wash, it shows up at bottom of kick panels and under center of floor pans.
there are no water leaks in the car systems. is it possible the water is coming in thru the cowl vents then down the firewall/kickpanels and under carpet.? are there seals /drains under vent cowl i can check/repair? thanks Allan |
![]() Join Date: Jan 2011
Re: water leak in cab, under carpet ?
Where under the carpet? Many car washes now have the sprayers the do the bottom of the vehicle. That will allow it to come in in a few places like the clutch pedal pass through and any other place that is low in the floors.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#3 | |
i will look for holes under as you mentioned also thanks |
Moderator
![]() ![]() Join Date: Aug 2011
Here is a thread on the kick panel vent repair: http://67-72chevytrucks.com/vboard/s...d.php?t=434587
There are drains between the cab and the fender for the kick panel vent. They do get clogged. http://67-72chevytrucks.com/vboard/s...d.php?t=687764 There are sometimes also holes in the floor. ![]()
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-19-2017 at 10:16 AM. |
I had leaks like you mentioned and what I found was that on the inside of the fender well where the side kick panel meets the floor board that it is spot welded and also has seam sealer on the joint. Over the years the seam sealer had dried out and some of it had fallen out. When I washed the truck the water would go behind the cowl extension and leak down to the seam and leak on the inside.
I managed to get it chaulked up with out removing the wheel but would have been easier with the wheel off. |
Mine did the same thing. I replaced my vent seals and it fit it.
60-66 Nut
In my experience a wet floor is usually a result of a leak around the windshield.
But Found Her 25yrs Later!
This is where my leak was :
http://67-72chevytrucks.com/vboard/s...23#post6038323
thanks of all the good tips, my kick panels are carpet covered and the vent door assemblies are not there, will remove carpet and seal up the vent openings, see if that helps.i don't need the vents since i have A/C.
Water in the cab is sometimes from the roof gutters. See if the seam sealer has gone south.
Moderator
Also check the firewall where it meets the cab at the top of the firewall, you have to stick your head under the base of the hood, could be rusted and have holes.
good ideas, already sealed the roof gutters, they were bad, will now check the firewall area.
thanks |
What did you use for the drip rails?
#15 |
I had the same problem with my 65 Suburban. Drove me crazy trying to figure out where the water was coming from. Finally figured out it was the cowl vents inside. I used a "putty tape" and havent had a leak from them since but lost all my carpet because of the water.
#16 |
This is definitely a cowl vent issue. The water is coming in from the air inlet in front of the windshield, then pouring down the inside of these vents. The factory vent has a lip on it to keep the water out.
I modified my vents and first time I washed it...water was puddled up on the floor. Once I sealed these off, never had another drop of water in the cab. Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#17 |
Mines got a similar leak but not as bad. Only in heavy rain, there is a slight trickle down the middle of the cab behind the dash. Will investigate the cowl area!
Love this forum haha Cheers |
#18 |
I took my heater box out and installed a block off plate. I did not put anything on it like weather striping. Mine is leaking from there.
#19 |
my truck has no vents installed, just open holes
any ideas how i can cover and see them off? vents not used/needed as they are carpet covered and i have A/C Allan |
#20 |
I covered and sealed them still have leak , not coming from there so will try cowl top side area
