Old 10-18-2016, 10:30 AM   #51
mrtoni
Re: Carpet leveling mats
Any update. Needing as well
mrtoni is offline   Reply With Quote
Old 10-23-2016, 12:34 AM   #52
Cooper Restorations
Cooper Restorations's Avatar
I need one too
Cooper Restorations is offline   Reply With Quote
Old 10-23-2016, 06:32 AM   #53
tristan
Until I finally found an original set of leveling mats, which took a long time, I had tentative plans to have the carpenter who works on my house carefully measure and then rout out a set of "leveling strips" from old plaster lath or furring strips. That would be a good "garage business" for someone as I am sure that complete sets would sell well.
tristan is offline   Reply With Quote
Old 10-23-2016, 10:00 PM   #54
Ryanz
Re: Carpet leveling mats/Sound deadening
Mine has levelling matts - curious what anyone has done with theirs when putting in sound proofing material? I'm going to pull my carpet this winter and put Dynamat or something in to quieten the cab noise. i may just put levelling matts back in on top of material. Thoughts. And is Dynamat still the most recommended or is there anything newer that people are using now?
Ryanz is offline   Reply With Quote
Old 10-24-2016, 09:09 AM   #55
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Why not just fill the low spots with strips of Dynomat?
Tom Vogel is offline   Reply With Quote
Old 10-24-2016, 09:31 AM   #56
Ryanz
Well for as rare as the leveling mats are, I don't just want to sell them or not use them in some way for authenticity. That's why I was curious what others have done in the same situation.
Old 10-27-2016, 07:08 PM   #57
NorthernMatthew
NorthernMatthew's Avatar
any new developments on this mat project?
NorthernMatthew is offline   Reply With Quote
Old 12-31-2016, 05:50 PM   #58
Ryanz
Have bought the Dynamat which I will use for inside doors, back panels and possibly over the wheel wells as it's nice and thin. However, I have also ordered Dynapad which I will put on the entire floor. It's quite thick and supposed to help significantly in road noise reduction. Between the 2 it cost me about $1000! Really hoping this is worth it. I'll keep you posted. Anyone else with any thoughts or feedback?
Old 12-31-2016, 07:52 PM   #59
mrtoni
The template is narrower but the ridges match our blazer for 66-77 broncos. Not sure if it's available aftermarket but picked up a few and cobbled a set together for my blazer.
Old 05-22-2017, 05:12 PM   #60
themb2g
I was thinking of cutting a couple of these soundboards down to just make a flat surface. It only adds .5 inches to the height, but would level it out and provide sound protection. Thoughts?
http://www.homedepot.com/p/1-2-in-x-...85US/207168829
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
