Closed Thread
Old 05-22-2017, 09:33 PM   #5351
RickDeVon
RickDeVon's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by NoStopN View Post
I took one of my '02 trucks to the Goodguys show in Nashville. If I would have taken the un-air conditioned '69, I would be typing this dead. Anyway, have a look at what I find interesting.
https://www.flickr.com/photos/882049...57681920928421
That was one of the best shows I have been to in a long time...
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline
Old 05-23-2017, 06:05 AM   #5352
NoStopN
NoStopN's Avatar
The Goodguys shows have been so good that it is an automatic visit for me. Good car shows around Nashville are just very few & far between. There is one in January that I enjoy at the Fairgrounds that is also a must visit for me.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 05-23-2017, 11:12 AM   #5353
weq92f
weq92f's Avatar
Nice, thanks for the pics. That Stretch 5... er.. 7 window is sweet!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 05-23-2017, 06:48 PM   #5354
NoStopN
NoStopN's Avatar
You're welcome for the pictures. I've got to admit there is a ton of work done to most of them that makes me jealous. And ironically, I got behind a 4-door mid-60's Chevelle Malibu with a 3 on the tree on my way home. I watched the guy through the rear window.
NoStopN is offline
Old 05-24-2017, 06:24 AM   #5355
Not today, but Sunday I got tired of looking at the sun burnt woodgrain trim on the driver side of my '72 and decided to replace it. The truck needs rockers and one cab corner, I hope to go ahead and fix this summer. I was putting off the trim change till then, but had a little time to kill. The thing is unrestored and I'm keeping it that way long as is practical. Right now it's "keep the old truck going" over a restoration, just as would be when it was 10 years old. The truck must have sat under a carport with the western side open to the late sun. Or, the sun is just kinder from the east earlier in the day. The Cheyenne Super K/20 and Highlander K/20 both had the same thing.
Started out like this:
I had some refurbished mounting hardware and double stick tape on hand, so this little project cost virtually nuthin'
It was ugly under the trim, so I took a cup brush to it, coarse sanded, down to fine wet sanding, then black prime and paint
Just a small change, but mo' betta now
special-K is offline
Old 05-24-2017, 06:57 AM   #5356
flashed
Looks more gooder Tim ,nice truck .Cant wait to start driving my K10 if the upholstery shop ever gets my seat finished .I guess they need to be there to get it finished and they are MIA most of the time .
flashed is offline
Old 05-24-2017, 07:42 AM   #5357
That could be frustrating. I wish I wasn't using it for work, but at least I get to drive it every day. Must have put a couple thousand miles on it this month. Been running all over. I did get to take a long long meandering through my old stompin' grounds ride home on Saturday. Just the way these trucks were meant to be driven. Down along the creek, over the stone bridges, past the old houses and farmland,over the gaps just chuggin' on along. Set my mind at ease to say the least
Old 05-25-2017, 08:06 PM   #5358
BRL
BRL's Avatar
..I did get to take a long long meandering through my old stompin' grounds ride home on Saturday. Just the way these trucks were meant to be driven...Set my mind at ease to say the least
Some of you have real talent when it comes to working on these old trucks!
The only thing I did today was shove the key in the ignition, turn it to the right, crank up the stereo, and go for a nice long drive.
Definitely relaxing!
BTW, I have dual stereo amps. under the bucket seats, so I bolted dual toolboxes to my fenderwells, just in case of some kind of roadside emergency...and they've come in handy more than once.
BRL is offline
Old 05-26-2017, 06:26 PM   #5359
NoStopN
NoStopN's Avatar
Now there's a great idea. Just wear gloves. Nothin' says lovin' like hot tools from the ov...er, engine compartment.
NoStopN is offline
Old 05-26-2017, 06:43 PM   #5360
Metaldoc
Metaldoc's Avatar
I rubbed all the contact surfaces of the ash tray with candle wax and now it slides great. I keep my stereo remote and gum in it as I quit smoking 3 years ago.
Metaldoc is offline
Old 05-27-2017, 10:14 PM   #5361
OregonNed
OregonNed's Avatar
Restored my battery box
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 05-27-2017, 10:34 PM   #5362
DarkFlounder
Replaced the u-joints in the rear driveshaft, rotated the tires, removed the remaining parts from the old dual saddletank setup (floorboard tank switch, extraneous fuel lines), and cleaned out the garage a bit.
Tomorrow, it's all about the ignition (coil/points/cap/rotor/wires/plugs) and associated adjustments. Then, since the grease gun is out, re-lube the rest of the chassis.
And if time permits on Monday, shorten the steering column so my gut isn't constantly rubbing the steering wheel.
I'm losing the garage in a few months (moving to a less expensive apartment), so I'm trying to do as much as I can to keep the beast a reliable daily driver.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 05-27-2017, 11:40 PM   #5363
yuccales
yuccales's Avatar
Waterpump & PS hose both sprung a leak yesterday. So today it got done. Took my time, nice weather, no problems. Best of all, no leaks!
yuccales is offline
Old 05-28-2017, 09:50 AM   #5364
Metaldoc
Metaldoc's Avatar
I added about 150 miles to my odometer yesterday and two shows.
Metaldoc is offline
Old 05-28-2017, 05:10 PM   #5365
88fordf150
88fordf150's Avatar
Installed my headliner and set my grille in place temporary just to have a look see.
Brad handshoe
88fordf150 is offline
Old 05-28-2017, 06:24 PM   #5366
HO455
HO455's Avatar
Hhhhmmmmm. I suspect someone is going to have a tire wear problem. Unless that knuckle boom in the back is used to load Armco barriers for added traction.
Looks good dude.
RIP Bob Parks.
HO455 is offline
Old 05-28-2017, 06:37 PM   #5367
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Straightened an under-bed spare carrier, but more importantly removed the doors from the project for a stripped cab. With everything off it looks light. I think I'll skip the hoist and pull the cab four man power. Two old guys, my son and staunch nephew. That kid could lift the entire thing.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-28-2017, 06:39 PM   #5368
71CHEVYSHORTBED402
Straightened an under-bed spare carrier. More importantly, removed the doors from the project for a stripped cab. With everything off it looks light. I think I'll skip the hoist and pull the cab four man power. Two old guys, my son and stout nephew. That kid could lift the entire thing.
Tony
Old 05-28-2017, 07:26 PM   #5369
VWNate1
VWNate1's Avatar
Thumbs up Underbed Spare Carrier
That's very nice ! .
I've only ever found one really nice one here, with all the hardware etc. and it was far from home and had a locked spare on it, I was too tired to go back the next day and grab it, still sad I didn't but Old Men are not Young men, knowhutImean ? .
The whole dang truck was near perfect too : Grandpa's old long bed rig with a camper, donated as soon as he was in the ground I bet .
So many nice cars in Junk Yards here directly from those rip off charity donation places .
Maybe I'll find another one some day .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 05-29-2017, 12:18 AM   #5370
71CHEVYSHORTBED402
Re: Underbed Spare Carrier
Simple, but thanks. I was thinking about selling it, because I bought an in-bed carrier. An under-bed carrier is pain in the *&^ to change a tire. Down is dirty, up has to be a strain, and thankfully I'll never do it. I think I'll paint it with the new carrier, slap it back on just to have it........... So yeah, I do know what you mean.
Incidentally, I realized I have to drop the aux. tank to install said in-bed carrier to factory......Ha ha ha ha haaaaaaaa!. Maybe not HAVE to, but close for sure. The tank is worthless anyway.
Tony
Old 05-29-2017, 07:51 AM   #5371
hamjet
hamjet's Avatar
Looks good dude.
Yea, dad always wanted to know why my back tires were always bald on my muscle cars, I told him the rear must be out of alignment....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 05-29-2017, 08:36 AM   #5372
NoStopN
NoStopN's Avatar
Mine didn't have one, but I am so used to having the spare under the bed. I'll be looking to adapt a newer style winch under bed carrier to mine.
NoStopN is offline
Old 05-29-2017, 04:22 PM   #5373
BugzC10
BugzC10's Avatar
Parker her out side to admire while I probed the ground and dug holes tracing the sprinkler wire to locate the solenoids...what a pain...
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 05-29-2017, 07:17 PM   #5374
CG
BlahBlahBlah
I battled with my interior today. Finally got around to installing the seat cover I got from grumpy. Had the door panels already hung, but just barely. I was trying to reinvent the wheel and not have any screws showing. And in the months they were just hanging and getting beaten about it warped them a little so I ended up using more screws than if I would have just done it correctly the first time.
Went to put in the three points belts and middle belt I purchased 11 months ago and there is either a fitment problem with the two center belts or Im an idiot ... Leaning towards the latter lol.
Sorta cleaned and vacuumed out the cab when I got everything out. Let's see if pictures will download from my phone ...
CG is offline
Old 05-29-2017, 08:46 PM   #5375
NoStopN
NoStopN's Avatar
I moved mine around in the driveway. It may now get the garage space (but it's too long). At least I can get the windshield in the garage so I won't have to deal with dew on the windows. My new 4x4 won't fit in the garage & I just posted the yellow truck to CL.
NoStopN is offline
Closed Thread
