Old 05-23-2017, 01:10 PM   #276
solidaxel
solidaxel's Avatar
Re: Mike's 50
Heart pumping and blood flowing thru his veins !!
A long journey ahead
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-23-2017, 04:29 PM   #277
Flysocal
Re: Mike's 50
Congrats man sounds great. Wiring looks really good btw
Flysocal is offline   Reply With Quote
Old 05-23-2017, 06:42 PM   #278
focusedontheprize
focusedontheprize's Avatar
Re: Mike's 50
That thing sounds mean!
focusedontheprize is offline   Reply With Quote
Old 05-23-2017, 07:29 PM   #279
ptc
ptc's Avatar
Re: Mike's 50
Sounds real nice! - is that with muffs on? or just open headers?
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 05-23-2017, 10:27 PM   #280
mongocanfly
mongocanfly's Avatar
Re: Mike's 50
Sounds nice...real nice...always makes you feel warm and fuzzy inside to hear it start right up
mongocanfly is online now   Reply With Quote
Old 05-24-2017, 09:56 AM   #281
MIKESAD50
Re: Mike's 50
Thanks guys.
That was just open headers.
I, along with the girlfriend bled the brakes last night after work. She has been wanting to help, now hopefully she will be over that need.
It should now move under its own power, needed to get some more Trans fluid so quit last night. Also filled with coolant.
I'm pretty happy with the way the wiring has come out.
Now need to get to what I have been putting off and that is cleaning the bed sides and inner side of rear fenders for coating.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 05-27-2017, 05:51 PM   #282
MIKESAD50
Re: Mike's 50
Well worked a bit today. Cleaned and put a primer coat of POR15 on bed sides in prep for Monstaliner.
Also installed my seat frame .
I also started and ran engine to get up to and maintain 190* coolant temp.
Seems to be running to high fuel pressure @80psi.
It moved and stopped under its own power and drove it in to the shop today. Only 40 ft or so. But it moved aprox. 40 ft on its own!
Car show in the area tomorrow so will hit that up.
Hope to get some bedliner on bed sides tomorrow also.
1950 3100 5 window
Old 05-27-2017, 05:54 PM   #283
MIKESAD50
Re: Mike's 50
pictures forgot in previous post
1950 3100 5 window
Old 05-27-2017, 05:56 PM   #284
MIKESAD50
Re: Mike's 50
one more.
Next Saturday my buddy is suppose to come by the shop and work on front end, hood and door fit and alignment.
1950 3100 5 window
Old 05-27-2017, 11:12 PM   #285
oldman3
oldman3's Avatar
Re: Mike's 50
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 05-28-2017, 01:00 AM   #286
mongocanfly
Re: Mike's 50
Boy I like the stance...how far off the ground does it sit?..
Old 05-28-2017, 02:13 PM   #287
iowaboynca
iowaboynca's Avatar
Re: Mike's 50
Fires up....Check
Moves and stops...Check
Put a bow on it, sounds likes its done
This is a step i'm not looking forward to. Good look and looks good!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 05-28-2017, 04:52 PM   #288
MIKESAD50
Re: Mike's 50
Mongocanfly,
Bottom of front bumper is 4- 4 1/4" off the ground and rear of front fenders is about 4".
I like the stance also.
Looks lower now that I measured it. hope that will work, may have to raise it some.
1950 3100 5 window
Old 05-29-2017, 04:06 PM   #289
MIKESAD50
Re: Mike's 50
Got bed back on frame, didn't get much done with rear fenders
1950 3100 5 window
Old 05-30-2017, 10:57 AM   #290
Flysocal
Re: Mike's 50
Yep this one looks killer! Love the stance and patina. Keep the momentum
Old 06-04-2017, 02:58 PM   #291
MIKESAD50
Re: Mike's 50
Got some panel aligning done yesterday. Doors are tight and may have to change out the weatherstrip.
Need to adjust right fender to match hood alittle. But not bad overall. not looking for perfect gaps
1950 3100 5 window
Old 06-18-2017, 12:21 PM   #292
MIKESAD50
Re: Mike's 50
Got the new rear bumper installed with Splash Apron still needs some adjustment. I may down the road use the splash pan as practice panel to make some patina patches around truck later on.
I also got the front wiring done covered and secured less one spot.
1950 3100 5 window
Old 06-18-2017, 12:24 PM   #293
MIKESAD50
Re: Mike's 50
Also freeing up shop floor space the more this goes back together.
Still waiting on mufflers to show up, ordered more than 2 weeks ago.
Still putting off finishing the rear fenders for some reason. I really don't like doing it.
1950 3100 5 window
Old 06-18-2017, 07:00 PM   #294
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
Looking good coming together!
Advanced Design is offline   Reply With Quote
Old 06-24-2017, 03:49 PM   #295
MIKESAD50
Re: Mike's 50
Finally got my lazy self to clean and prime the rear fenders. Now just need to coat with the Bed liner.
This week I also finished wiring the rear lights. Everything except the turn signals work properly, turn signals dont flash.
Swapped turn and Hazard flashers, so will have to look into that.
Mufflers have finally shipped and should be here Wednesday. Been like 3 weeks since ordering.
1950 3100 5 window
Old 06-26-2017, 11:39 AM   #296
tlorber
tlorber's Avatar
Re: Mike's 50
Mike,
Do the bulbs for your rear lights have 2 filiments? I'm getting close to ordering some taillights for my '54. I'm assuming that since they did not use turn signals back in the day, that original lights would not work for running/brake/turn signals. Is that correct, or am I overcomplicating this?
I was also wondering of any fixtures have backup lamps in them.
tlorber is offline   Reply With Quote
Old 06-26-2017, 12:57 PM   #297
MIKESAD50
Re: Mike's 50
Tlorber,
I have LED lights in back.
If you have a dual filament you can have tail and brake turn lights depends on how the brake and turn signals are wired.
And yes original you wont have all three rear lights in one housing
1950 3100 5 window
Old 06-26-2017, 05:45 PM   #298
MIKESAD50
Re: Mike's 50
Got the rear fenders coated with 2 coats of bedliner over the POR15 and bolted up, set the running board on check fit, will need to get the running boards mounted and adjust fenders to fit, filler panel not sitting properly and hitting cab.
Looks the same as when I got it 3 years ago.
1950 3100 5 window
Old 06-28-2017, 07:40 PM   #299
MIKESAD50
Re: Mike's 50
Mufflers showed up today. Stainless Works Turbo Chambered 2 1/2"
Hope to get truck over to shop Thursday, that will install exhaust.
1950 3100 5 window
Old 06-30-2017, 01:14 PM   #300
MIKESAD50
Re: Mike's 50
Ready to load up and off to exhaust shop.
1950 3100 5 window
