71 5 lug posi 12 bolt and front brake parts
As title says 71 C10 rear axle 5 lug posi unit and 5 lug rotors, spindles and calipers. . Rotors calipers and bearings have 100 miles on them, planning on a dually conversion so I won't need any of it. Price is 850 or best offer
Re: 71 5 lug axles and front parts
Pic of spid and truck
Would like to know the Gear Ratio of the Posi unit ???
![]() Join Date: Sep 2016
Hard to see spid is this a leaf spring rearend
Depending on what gear ratio is but if you decide to sell posi separate I may be interested
![]() Join Date: Mar 2011
and if you break it up i would be interested in the complete rear brake setup
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
I'll check ratio this weekend, however I will not disassemble rear axle to remove the chunk. If I do the price for chunk is same as buying the entire unit.
![]() Join Date: Jun 2010
do you still have this rear end?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
If u wanted to sell the brake parts to zicc1835, I would be very interested in the rest of the rear. I am close (Roanoke, Va.) so p/u would not be a problem. Guess I better ask- I would be putting in a 68, same width etc.?
Sorry to respond late but I sold entire truck
