Old 05-22-2017, 08:44 AM   #1
Jorgeg15
Jorgeg15's Avatar
Clicking noise behind dash when accelerating
Gents,
First post! Unfortunately I have to start it off with an issue.
Does anyone have any prior experience with this specific issue?
On my 1971 C10 350/350 combo
When accelerating from a stop a loud clicking noise from what seems behind the dash area. Also when it clicks the truck will hesitate.???
I've checked out the relays, flywheel, general inspection and cannot find anything to be the cause. It doesn't do it every time; very intermittent.
Thanks for the help guys.
Jorgeg15 is offline   Reply With Quote
Old 05-22-2017, 09:54 AM   #2
DPowell
DPowell's Avatar
Re: Clicking noise behind dash when accelerating
Have you checked your speedometer cable? It can be noisy when it's spinning without lube. That won't have anything to do with the truck hesitating though.
'72 C10 Short Fleet
"Praise the Lowered"
DPowell is offline   Reply With Quote
Old 05-22-2017, 10:34 AM   #3
Leftlane
X2 on the speedo cable needing lube.
Check the near wiring to make sure the speedo cable jacket hasn't worn through any creating a short as it wobbled.
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 05-22-2017, 10:53 AM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Check your left motor mount, it could be allowing the motor to lift and the fan blade to hit the shroud. The hesitation would then be the carb linkage binding.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-22-2017, 01:21 PM   #5
cleszkie
cleszkie's Avatar
Clicking could be due to a burnt plug wire. The arc from the burnt wire to whatever it is grounding on will make a clicking sound. This would also account for the hesitation. When its clicking, its arcing, and you essentially have a dead cylinder.
cleszkie is offline   Reply With Quote
Old 05-24-2017, 03:06 PM   #6
BILT4ME
Check the wires on your ignition switch that could be shorting out against the firewall or the dash. That will make it hesitate because it shorts the ignition. The clicking you are hearing could be the sparking when it's happening.
Also check your fuse block for shorts.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 05-24-2017, 04:04 PM   #7
70STOVEBOLT
Please post your findings and/or solution here so other members can benefit from the info.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 05-24-2017, 05:30 PM   #8
Daves70
Daves70's Avatar
Drivers side exhaust manifold leak?
Daves70 is offline   Reply With Quote
Old 05-25-2017, 01:40 AM   #9
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 05-25-2017, 09:00 AM   #10
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Welcome to the forum!!
This is where you can find the answers to your issues.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is online now   Reply With Quote
Old 05-25-2017, 01:06 PM   #11
davepl
davepl's Avatar
When someone joins and their single, only-ever post is to ask a somewhat obscure troubleshooting question I doubt they ever come back to follow it up. We'll see however, maybe this one is an exception!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-25-2017, 08:03 PM   #12
chefk85
chefk85's Avatar
I had a similar issue and it turned out to be speedo cable. I took the dash out and subsequently the cable and lubed out. Then took it out of the cable sheath and lubed with dry graphite. It fixed the issue. I had an erratic speedo as well when this was happening. If that's not it and the engine runs well then I'd be checking for an exhaust leak.
http://67-72chevytrucks.com/vboard/s...25#post7532025
71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress.
79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos.
93 Burb K1500. 350/4l60e Parting out.
2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles!
chefk85 is offline   Reply With Quote
