Fuel gauge wire at fuse panel
1970 c10
My fuel gauge been acting a bit strange. I checked for power where the tan lead connects at fuse block. I tested It for power with a tester with light bulb. The bulb was dim. That should be a 12v source right? Thanks for any help you can provide. Thanks. Mark Posted via Mobile Device |
Re: Fuel gauge wire at fuse panel
The easiest way to troubleshoot fuel gauge problems is at the sending unit. Don't mess with the cluster or fuse box until you do this first: Slide your seat forward, and with the key on disconnect your tan wire at the sending unit. Your gauge should now read about 3:00. Now ground the tan wire against the top of the sending unit, or the fuel tank, or a known good ground. The gauge should now go to empty. If those two steps work, everything is working properly all the way back to the gauge.
That tells you the problem is in the sending unit <<<< from bstock |
True doc if your gauge has regulator . if in sender should be less
#4 | |
I just thought it odd that the power from that connector at fuse block was weak. Is that wire to the fuse panel a 12 volt source for the sending unit? I'm guessing it is If so I would pick up that power elsewhere since it's weak. Posted via Mobile Device |
gauge reads resistance (ohms) so dont want full voltage
the question is:
Is the tan wire a 12 volt source? Posted via Mobile Device |
NO 12 v comes from ign switch
Ok. So that tan wire connects to a voltage Lower than 12v right?
If so got it. I cleaned up conendctor at sending unit and it seems fine. thanks for the info. Mark Posted via Mobile Device |
np
