Old 04-08-2004, 11:14 PM   #1
hanssolo
hanssolo's Avatar
poly cab mount clunking
Does anyone have to tighten their poly mounts on their cabs that seem to loosen up a bit over time that causes loud cab-shifting clunks on tight turns . Or is this another freak problem that only I have again! I want the soft rubber ones back(not to mention better ride.)
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 04-09-2004, 06:11 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My poly mounts have been on for over 2 years and I've never had to re-tighten the body bolts. Did you use pinch nuts or nuts and split washers?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-09-2004, 07:39 AM   #3
Dean
Dean's Avatar
I haven't had mine loosen up but I did have two split and fall apart. I'm not fan of them anymore.
Dean is offline   Reply With Quote
