Old 05-29-2017, 08:34 AM   #1
Nima
Blue 67
LM7 in 67 C20
Hi:
Can this engine be dropped in to a 67 C20 without major modification such as swapping the intake and accessory drive components? How about the oil pan? I know the wiring and fuel pump has be modified.
And while we are at it, is there a manual transmission which can go with it or I would be better off with an auto behind it as far as the modification to the cab's floor? It would be just a daily driver.
I have a LM7 with all the accessories and wiring that I wanted to drop in my 79 Camaro but it seems I have to sped twice as much I paid for the engine to swap the intake, accessory bracket and etc. It might make a better financial sense to just get a car LS engine for Camaro.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 05-29-2017, 08:54 AM   #2
jessemthompson
Re: LM7 in 67 C20
The lm7 drops in with the factory intake, oil pan and accessory drive. There is an LS swap section here in the forums. It has tons of information that helped guide me through my swap.
jessemthompson is offline   Reply With Quote
Old 05-29-2017, 09:05 AM   #3
mongocanfly
mongocanfly's Avatar
Re: LM7 in 67 C20
On the transmission its a matter of what your looking for...I have a nv4500 behind mine...works great...as far as expense there's not much difference between going auto or man..matter of choice..
and yes if your putting a ls in a car its much less expensive to use a car ls engine than trying to swap everything over..
Old 05-29-2017, 12:31 PM   #4
Nima
Blue 67
Re: LM7 in 67 C20
Thanks, I assume for nv4500 I have to cut the floor or can it be column shift? How about auto, can that be Column shift?
Old 05-29-2017, 01:16 PM   #5
jessemthompson
Re: LM7 in 67 C20
The auto can be column shift. Idk of a way for the NV4500 to be. I wouldn't think so. I've never seen anything but a floor shifted 5 speed.
