Old 05-25-2017, 10:18 PM   #251
mongocanfly
mongocanfly's Avatar
Re: 1949 Chevy 3100 Build Thread
I can't get under my 81 enough to get a good pic but this sketch is the way my tank vent is..on the tank there's 2 nozzles..one for fill one for vent...on the fill end there is a 90* fitting welded onto the main fill tube on the upper side of the tube and close to the mounting flange..if the gas nozzle is inserted in the filler the 90* elbow is behind the nozzle tip
Old 05-26-2017, 12:36 PM   #252
Flysocal
Originally Posted by kameltoes2015 View Post
What kind of hose are you thinking of using with the Fragola fittings on the transmission
I bought the matching fragola 6an hose it's black braided.
As for the tank venting, I called NO LIMIT and they said the tank is already vented to account for filling. If you look into the filler tube on the tank you can see a dedicated tube/chamber that leads to the other side of the tank where a NPT bung is welded. This is where I install the vent fitting and I run it to the frame rail at a point higher than the filler. If I need a second vent that would suck im going to trust no limit on this one and hope it works. When the chassis gets loaded on the trailer I will take it to the gas station and try it out.
Flysocal is offline   Reply With Quote
Old 05-26-2017, 12:42 PM   #253
Flysocal
Old 05-26-2017, 12:51 PM   #254
solidaxel
solidaxel's Avatar
What size vent opening in the tank do you have?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-26-2017, 01:08 PM   #255
solidaxel
solidaxel's Avatar
More mind searching !
I bought a 1/2" fitting and drilled out a location in the pump/fuel line cover, there is room for this fitting with the 2 fuel lines and roll over vent in this plate.
from there we went to the filler neck as high as we could and placed another 90* fitting in the rubber filler hose.
We can now put fuel in the tank but still need to be a bit careful as you can not rush the fill up, fuel in'air/vapor out
I did have trouble sealing the gasket around the plate for the pump and lines, so I am glad we found this out before the bed wood was in place
LS 3 4L70E
Old 05-26-2017, 01:30 PM   #256
Flysocal
That's a good point my painter offered to install my wood bed but I think I will need access until all the bugs are worked out. The wood will get installed once I'm happy with everything. The vent bung is 3/8 NPT. I'm gonna move onto the next since I won't know until I get to a gas station.
Old 05-26-2017, 06:15 PM   #257
mongocanfly
I believe you won't have any problem with that vent..as long as the tank air has somewhere to go when your filling..except maybe where to mount the vent higher than the fill...
Old 05-27-2017, 06:13 PM   #258
MIKESAD50
Flysocal,
How did that Frame less 1 piece glass work ? Did you trial fit it?
Thickness wise how does it compare to the stock framed glass? is the felt channel different than stock?
Nice progress
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 05-28-2017, 11:43 AM   #259
Flysocal
Originally Posted by MIKESAD50 View Post
Flysocal,
Nice progress
Honestly I don't know I didn't want to fit the glass and felt only to damage it when taking it all apart again. So it has not been mocked up.
I have 49 doors so did not need the 1 piece conversion kit. All I can say is the kit is nice quality and I'm feeling good about it. The glass is the same thickness but frameless so the kit included special felt to account for this. Check back in a couple months and I will have an answer....
Old 05-30-2017, 03:40 PM   #260
Flysocal
Plugging away on little things while I have full access. ICT billet called for a 107" belt with standard alternator (what I have) did not fit so I ordered a 108" which also didn't fit (see pic). Had to go with a 109" belt, third times the charm. After several attempts at lower radiator hose I bought a long piece from orielly that had sever bends and cut it to size so that's done. Installed these trick white LEDs for my license plate from radiantz. I've used their products on my choppers and have been happy. Got my exhaust back from ceramic coater so that will get installed today, then I can finalize routing for fluids.
Old 05-30-2017, 09:17 PM   #261
Flysocal
Installed the exhaust. Glad I had it ceramic coated. Light duty tow hitch installed which also provides a little protection for the battery. With the exhaust installed I can start running my fluid lines. So far all I've got done is front braided lines installed left side goes direct to earls tee. Right side attaches to bracket then hard line along front crossmember to tee. I will work on this tomorrow.
Old 05-30-2017, 09:34 PM   #262
mongocanfly
Those exhaust pipes look good coated....never really thought about doing the whole setup coated...im gonna be using all stainless pipes on mine..
Old 05-30-2017, 11:23 PM   #263
kameltoes2015
Sweet!!!
kameltoes2015 is offline   Reply With Quote
Old 05-31-2017, 12:09 AM   #264
mongocanfly
Like those tag lights...got any part numbers for em?
Old 06-02-2017, 10:00 PM   #265
Flysocal
Randiantz.com and look for "top fx"
Got the plumbing all layed out now waiting on a few more fittings before I can finalize. Got the rear brakes installed and parking brake cables routed. Just a couple more solid days in the garage and I can hand chassis over to the painter.
Old 06-03-2017, 01:39 PM   #266
solidaxel
solidaxel's Avatar
You are really going to enjoy the ride, what springs do you have in front and rear?
LS 3 4L70E
Old 06-06-2017, 11:57 PM   #267
Flysocal
Aldan coilovers that came with my Scott's kit.
Plumbing is almost done. Waiting on a couple more fittings but you get the idea. Ktools flaring tool worked nicely. 3/16 sur&r nickel copper hard lines. Very nice stuff and easy to work with. I bent the lines by hand and it's impressive stuff. Fragola braided fuel lines.
Old 06-07-2017, 12:05 AM   #268
Dan in Pasadena
Dan in Pasadena's Avatar
Wow! Everything looks fantastic. Really impressed.
Who did you use for your ceramic coating?
I hadn't considered black before but it looks great and long term will probably look better than the shiny silver ceramic I had in mind. Have you used it before? If so, for how long and how has it held up? Thanks for the info on radiantz!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-07-2017, 01:08 AM   #269
Dan in Pasadena
[URL=http://s980.photobucket.com/user/flysocal77/media/E0DA73AE-C7A2-4E5C-99BF-EFD45D0C089A_zpsscbthg1e.jpg.html][IMG]
Flysocal, Maybe we discussed this before - I admit I don't recall. Your rims are Boyd's Junkyard Dogs, right? What size? My rims are Boyd's Smoothies but I don't know if theyre originals. I assume there was such a thing as Smoothie II's and Smoothie III's?
Old 06-16-2017, 11:23 PM   #270
Flysocal
junkyard dog wheels 20x8.5 rear with 5" BS. 18x7 front with 4" BS
Old 06-16-2017, 11:29 PM   #271
Flysocal
Chassis is ready for pickup. Painter says he will pick it up on the 25th. Nothing left to do right now so I'm taking a break for a bit.
Old 06-16-2017, 11:39 PM   #272
Flysocal
Sold the 71 Camaro because the wife wants a convertible cruiser. Did the unthinkable and bought this sight unseen from NJ. Seems crazy bringing a NE car to Cali but the price was right and I couldn't resist. It's a 1968 Firebird Convertible. With the garage freed up for a couple months I can clean this up, put new quarters on it. Hopefully it's not worse than the pictures lead me to believe!
Old 06-17-2017, 12:59 AM   #273
mongocanfly
Truck chassis is lookin good..you'll have to start a droptop build in the alternative section..
Old 06-17-2017, 02:54 AM   #274
Nut Case
Nut Case's Avatar
Super Fly
Hot diggitty dog!!! Your in the last stage. Strong work, Thanks for sharing, I've pirated may photo's. Many thanks
Keep on keepin on
NC
Can ya dig it
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-17-2017, 04:52 PM   #275
joedoh
joedoh's Avatar
gorgeous work, I would probably never drive that truck just wipe it with a diaper and mutter "my precious" till they called the doofy wagon on me.
my experience with nj cars tells me you might be a little optimistic but hey, the heart wants what it wants!
