Old 05-31-2017, 02:03 AM   #1
mr48chev
mr48chev's Avatar
Re: Help Identifying Front Clip and Suspension Parts on 1956 Chevy Pickup
For those of you who think it is 78 or later those are NOT metric calipers. This throwing nonsense out just to hope you look knowledgeable only adds to the confusion and doesn't help for squat.
I stick to my original comment which coincides with with 1958Warrior In that it is a 75 to 77 Monte Carlo subframe . Still almost all parts interchange with Mullet Camaro, 73/77 Chevelle, Regal, Cutlass, Lemans outside of the sway bar bushings and maybe a couple of other things. The frames are slightly different but almost all the pieces that bolt to them are the same.
My ongoing truck projects:
Old 06-01-2017, 09:30 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
You may well be right , any of the components may have been changed and the fact that they will swap to many different cars makes it less important on specific year. General year and what replacement parts work is the important issue. If he can get some bushing numbers I asked him for we'll know then with much less guessing and more certainty at least to a year range and body style
Old 06-02-2017, 11:29 PM   #3
mr48chev
mr48chev's Avatar
Taking a caliper and measuring the front sway bar will get the correct sway bar bushings.
I don't think I have a photo 1 of the 75 Monte Carlo frame I put under my 51 Merc in the late 80's. I'm thinking it had that lip sticking out from the crossmember that served as a skid plate or something.
Here is an Ebay add for a 73/77 Monte Carlo frame that is a bare frame and it has that lip/protrusion or skid piece on it.
If memory serves right the Monte Carlo frames had 3 degrees + caster built in while the Chevelle style had 1 or 1-1/2 built in.
Old 06-03-2017, 12:14 PM   #4
oracle56
I would like to thank everyone for helping. I am a novice at this stuff and I could not have found the answer by myself. As a matter of fact, I have been grappling with this issue for over 2 years now. I "assumed" that the front clip was a Camaro but could not figure out a way to confirm it. I have been googling 100’s of chassis pictures but never hit the correct one. Being new to this, I assumed with all things “google-able” there would be a website with every frame ever made and it would be a simple task to find my frame. It was not. I looked at so many frame pictures I was going “framing crazing”. I was not aware of the small differences of each vehicle’s history that makes this identification possible. That is why this collaboration with others on this website is so amazing and a wonderful resource for knowledge and guidance. It is a rare treat to have others give of their time and effort to help someone. Thank you!
As for the brake calipers, I had replaced them in 2013. What I documented for the “original” casting numbers were Driver (L): 5474338 CFD 388 (or 338) and the Passenger (R): 5474339 CFD 339. I had replaced them with Right Caliper (Model 18-4059) and Left Caliper (Model 18-4060) from Summit Racing.
I have been discussing this with dwscr and using the information provided by all. I think it has been concluded that this is a 1977 Monte Carlo front end. Again, I would never have been able to identify this without everyone’s input and assistance. I would like to layout the steps and information that has drawn us to this conclusion which may (or may not) help someone in the future.
1) I tried to check the control arm bushing for markings but they are so old that any markings were long gone so there was nothing to identify there.
2) 1958Warrior pointed out the indent in the frame. Then he found two pictures on www.lowrider.com that had good pictures of the frame of a 1977 Monte Carlo.
3) I then compared my under side with that of one of the pictures found by 1958Warrior. As you can see my under carriage looks very similar.
oracle56 is offline   Reply With Quote
Old 06-03-2017, 12:16 PM   #5
oracle56
4) I then compared my Driver Side Frame with a picture 1958Warrior found (see arrows).
Old 06-03-2017, 12:18 PM   #6
oracle56
5) I then compared my Passenger Side Frame with the picture (see arrows).
Old 06-03-2017, 12:19 PM   #7
oracle56
6) Once on the scent for a 1977 Monte Carlo because the facts were starting lineup, I found another picture at www.layitlow.com.
