06-07-2017, 11:24 AM | #1 |
another brake question 70 c-50
I am trying to get my brakes working on my 70 c/50 without converting to hydroboost. I have the master cylinder on the firewall and the booster under the cab. I replaced the master cylinder and began to bleed the brakes. I got good fluid from the remote master under the cab. then went to the rear. both the rear bled out fine. the fronts however will not bleed. i removed the bleeders completely to make sure they are open and not clogged up. they are clean and I can blow through them. but no fluid comes out. I cracked the line where it splits and goes to the 2 front wheels and I am getting good pressure there. I am thinking its either the rubber hoses going to the front wheel cyliners are collapsed inside or I have a wheel cylinder problem. Has anyone experienced this before?
06-07-2017, 12:40 PM | #2 |
Re: another brake question 70 c-50
seen more than a few hoses go bad . . . mopar had a problem years ago in there smaller / mid size cars with 1 rear hose going bad and holding pressure on the drum brake and locking it up . i changed a lot of them .
so fast easy thing is the hoses to change .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
