Old 06-07-2017, 10:01 PM   #1
Truckdriverjames
Talking Droping 292 oil pan
Took a few minites under the pick up thinking that the fun level on droping the pan isnt very high on this one and looking for some insight before i really get in a jam. Ive got a small rod knock im hoping to get it fixed before it totals the motor.
Thanks!
Truckdriverjames is offline   Reply With Quote
Old 06-07-2017, 11:56 PM   #2
B. W.
B. W.'s Avatar
Re: Droping 292 oil pan
4wd you can remove the engine cross member, 2wd not sure you can do it.
B. W. is offline   Reply With Quote
Old 06-08-2017, 12:00 AM   #3
Truckdriverjames
Yeah that aint gunna happen with the 2wd for sure.
Old 06-08-2017, 04:56 PM   #4
Wrenchbender Ret
It can be done but like you say, it is not fun. You need to take the front mounts loose 7 raise the front of the engine way up. Pull the fan so it won't poke the radiator. Remove the flywheel covers. You may have to rotate the crank if the front balance weight is down.
Wrenchbender Ret is offline   Reply With Quote
Old 06-08-2017, 04:57 PM   #5
Truckdriverjames
Talking Re: Droping 292 oil pan
Happy i decided to just yard the motor out
