Re: Rear drums removal on a 67 C50
the nut only holds the bearing preload ( and especially after much use ) may be loose to the point you don't need the tool....or only a small brass or aluminum punch to loosen it.... then you can take the nut in with you to get the tool for reassembly. just be sure to "unlock" the tab first
