Old 06-08-2017, 11:29 AM   #1
67z28
1954 Under Bed Side Tank
Is there a factory style fuel tank that will fit on the inside of the frame under the bed? I would like to run a factory sending unit if possible. Any help would be great.
67z28 is offline   Reply With Quote
Old 06-08-2017, 01:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1954 Under Bed Side Tank
Very doubtful that youll find anything off the shelf thatll work...just not much room in that area...the best thing to do would be put a tank between the frame rails behind the rear axle..there are several that have been used ..blazer, mustang, aftermarket, such as boyds welding and others..
Old 06-08-2017, 04:35 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Take a look at this from Jim Carter
http://www.oldchevytrucks.com/blog/i...tanks-1947-55/
It may work for you
Old 06-09-2017, 08:17 PM   #4
Tsunami
Tsunami's Avatar
I used a 1957 Chevy fuel tank between the frame rails located behind the rear axel. I've not seen, not to imply someone doesn't manufacture something, side tanks. Ricks Tanks (http://rickstanks.com) might be able to fab something up for you.
Tsunami is offline   Reply With Quote
