Re: Gas tank rusted out on 87 gmc suburban 4x4
I also did this job a few times. Yes on the jack in the middle but it's hard to balance.
I used two sets of come-a-long straps on each side. Used the jack to support in the middle, loosened each strap evenly, dropped tank a bit and repeat. I was able to walk the tank down by myself several times with a 1/2 tank of gas. Several times means: leaking new tank, pump not working, pump not working.....discovered my electrical connector was soldered so re-did connection. Lesson learned.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
| Bookmarks |
| Tags |
| 1/2 ton, 1987, 4x4, gmc, suburban |
