Old 06-09-2017, 01:29 AM   #1326
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
And of course the original flex line was all dried up and cracked, so I went to a local shop that specializes in hydraulic hoses and got them to build this, it's pressure rated to 3000psi and has a female 3/8-24 fitting on one end and a female 7/16-24 fitting on the other end. The price was pretty reasonable as well.
62stepside longbox is offline   Reply With Quote
Old 06-09-2017, 01:32 AM   #1327
62stepside longbox
Re: Nik's 62 build
And I used this little piece screwed to the firewall underneath the booster to secure the hard line right near where the flex line connects. I also got the interior pretty much back together other than the floor mat and cleaning up some under-dash wiring. https://youtu.be/TeX3qZG2CM0 plus I installed the tank with sending unit for the final time and put a little gas in the tank, as you can see in the video the gas gauge is working just as it should.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 06-10-2017, 10:01 PM   #1328
SSpeed66
SSpeed66's Avatar
Re: Nik's 62 build
Did you go to Allens Hose N All for that ?
Living The Canadian Dream in British Columbia
SSpeed66 is offline   Reply With Quote
Old 06-10-2017, 10:55 PM   #1329
62stepside longbox
Re: Nik's 62 build
Yes
Old 06-11-2017, 08:42 PM   #1330
RANDY COX
RANDY COX's Avatar
Re: Nik's 62 build
That was a great mod on that radio delete plate nobody would ever suspect that there's a hidden radio back there...That's getting creative.. That's what it's all about making the truck your own...good job keep up the good work....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-11-2017, 09:45 PM   #1331
62stepside longbox
Re: Nik's 62 build
Thanks randy! Little touches like this is what will make this truck so unique compared to all the others out there.
Due to the truck being parked in the same place the entire time I've owned it lots of random crap has gotten piled up in and around it. So I spent the morning taking a load to the dump and sweeping out the bed and the interior. It's staring to look like a truck that might actually run now😂.
Old 06-11-2017, 09:48 PM   #1332
62stepside longbox
Re: Nik's 62 build
Since the original bed wood was completely rotten I just bolted in the piece of plywood I had laying around. It doesn't look too pretty but it will allow me to use the bed, eventually I will put some nice planks of oak in the back, but that will be at least a year or two down the road.
Old 06-11-2017, 09:50 PM   #1333
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
Looks good!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 06-11-2017, 09:50 PM   #1334
62stepside longbox
Re: Nik's 62 build
Originally Posted by Classic v6 GMC's View Post
Looks good!
Thanks Andy!
I then drilled the hole for the brake hose on the passengers side and bolted it in, all that needs to be done is the passengers side upper shock mount welded in and the front end will be completely done
Old 06-11-2017, 09:54 PM   #1335
62stepside longbox
Re: Nik's 62 build
I also worked on making some tailgate latches. Some of you might remember that last year I picked up a chrome set of seat belt buckles from a Cadillac in picknpull exactly for this. I bolted the female end of the buckle to the bedside, I still need to get the correct length bolts.
Old 06-11-2017, 09:55 PM   #1336
62stepside longbox
Re: Nik's 62 build
and then I welded the male end to the tailgate
Old 06-11-2017, 09:58 PM   #1337
62stepside longbox
Re: Nik's 62 build
And here it is latched, it actually works very nicely. That's all for today, thanks for watching guys.
Old 06-12-2017, 11:04 AM   #1338
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Nice! Like the tailgate latch! You gonna maybe create some kind of cover to help protect it from the elements?
Old 06-12-2017, 11:54 PM   #1339
62stepside longbox
Re: Nik's 62 build
Thanks tj, both pieces are Chrome, other than the weld which I will be painting. So the weather shouldn't hurt them too badly. If water gets inside the buckle and eventually seizes them up then I'll simply just go to the junkyard and get another set and bolt them right on, I think they were only like $5 or something.
The truck needed a coolant overflow reservoir, so out came a redneck rye bottle 😂
Old 06-13-2017, 09:07 PM   #1340
SSpeed66
SSpeed66's Avatar
Re: Nik's 62 build
Hey Nik. I'll be getting a local old boy who has a wood shop to do the cutting & milling of my bed wood, probably out of local Douglas Fir as there is so much of it here. If there were 2 of us going together on it, it might be a lot less $$$
Old 06-13-2017, 10:43 PM   #1341
62stepside longbox
Re: Nik's 62 build
Just sent you a message on Facebook
Old 06-14-2017, 11:27 PM   #1342
62stepside longbox
Re: Nik's 62 build
Found a belt that was the correct length, so I put it on, filled up the power steering system with fluid, and fired the truck up. It works amazing! I can literally steer with one finger. Here is a video https://youtu.be/OI1DWWKVpy4. One question though, I've never driven anything old with power steering, is it normal for the idle to drop when the wheels are at full lock on either side?
Old 06-15-2017, 05:11 AM   #1343
Re: Nik's 62 build
Yes, at full lock the pump puts a bigger load on engine.
Old 06-18-2017, 09:09 PM   #1344
62stepside longbox
Re: Nik's 62 build
Thanks for the response bill, I figured that was the case but wanted to ask just to be safe.
The past week I've been extremely busy with schoolwork with things like finishing all of my classes and preparing for final exams. And to add on to it, work is getting busier as well. But today I spent an hour or two on a few little things. One of them was wiring the truck for reverse lights since the new transmission has a built in reverse light switch. The dash already had this cool little light in it when I bought the truck but it wasn't hooked up to anything, so I picked up a new bulb for it and wired it to the reverse lights. So when you put the truck in reverse the light will be illuminated. It's the little things that count
Old 06-18-2017, 10:00 PM   #1345
namloc
namloc's Avatar
Re: Nik's 62 build
Awesome I think I can here it running from Seattle.Like the Cadi. latche's.And the indicator light.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 06-30-2017, 09:38 PM   #1346
62stepside longbox
Re: Nik's 62 build
Thanks.
Well I've been extremely busy with lots of little things, I just finished writing all of my exams and am now finished grade 11😃. Also took a few days to go on a fishing trip. And to add on to all of that I've also been very busy at work. But despite all of these distractions I still managed to meet my goal of having it driving in June, well sort of... Last week I got the hydraulic clutch lines installed and bled out. So I took it for a drive around my street! It was awesome! However the reason I say I "sort of" made my goal is because it still has no brakes, I was just using the ebrake while taking it around the block. The braking system is all finished, however I've been having lots of trouble getting it to bleed! I think I might need to get the special tool that keeps the combination valve centred. Here is some of the progress I've made in the past week. I finally welded on the passengers side upper shock mount and installed the shock.
Old 06-30-2017, 09:54 PM   #1347
62stepside longbox
Re: Nik's 62 build
And these here are some rear bumper brackets I built about a year ago, and I finally got around to the point where I was ready to weld them to the bumper. But I realized they were not strong enough because the amount of metal I took out when making the oblong holes. So I welded gussets on the ends and they are much stronger now, here is the finished product.
Old 06-30-2017, 10:06 PM   #1348
62stepside longbox
Re: Nik's 62 build
I then welded those two pieces to the bumper and bolted them on to the pieces of angle iron that sit inside the frame rails. Here it is, the clamps are there because the pieces of angle iron still need to be bolted to the frame.
Old 06-30-2017, 10:08 PM   #1349
62stepside longbox
Re: Nik's 62 build
Also installed the west coast mirrors, I absolutely love the look of these!
Old 06-30-2017, 10:12 PM   #1350
62stepside longbox
Re: Nik's 62 build
So with mostly everything finished up other than the brakes still needing to be bled, I am just about ready for the road! I am leaving tomorrow for a two day fishing trip and after that I am going to get my wisdom teeth pulled. So I'll be out for a few days, but once I'm feeling better I'm going to try to get the brakes figured out and then put insurance on the truck!
