#26 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Who has done a 4BT swap?
It varies, but after the swap is always better. My wife's V10 excursion went from 6-11 to 18-20. An 89 V2500 suburban with a TBI 350 to a 12v was 8-12 before, and 15-18 now. And that truck has 3.54 gears with 35" tall tires. He tows a 10k dump trailer with it and a pretty good sized enclosed trailer with it and said he could never go back to the gas engine in it. My 72 I can't tell you before because it didnt run when I got it. But it was a 402 4 speed truck. It gets 17 with a mix of highway and in town driving. I hauled a skid loader a hour and a half away, which was 23k loaded. When I filled the tank from that trip it averaged 14.8. I was running 70-75 on the interstate. It would get better if I pulled some fuel back. It is pretty over fueled right now. I have not dyno'd it but it pulls like any other 600-650hp truck we've built. You have to watch your skinny pedal.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#27 |
Today, right now, in 2017, I wouldn't swap a diesel into anything.
Gas is cheap, and diesel's are expensive. Given a choice between a Duramax and an 8.1 truck with the same miles, the dmax being cheaper, I took the 8.1, and am pleased as punch. Back in 2006, I swapped a K5 with a 4BT. I paid 2300 for the entire stepvan, scrapped the aluminum from the body for 1,200, sold my old 350/700R4 for 600, sold the TH400 from the van for 400. That brought me down to 100 for the engine, after everything I was into the swap for around 1,000. It had 3.08's, got around 18 mpg, cruised at 75 easily. It was not faster than a 454, it was about as fast as a healthy 350. Now, that you have brodozers and every kid on Instagram #rollincoal with 9" stacks and crap, you can't touch a bare 4bt for less than 2k. It's way to costly to ever make sense financially.
J.R. Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010 Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer |
#28 |
I have looked up stock mpg on trucks gas vs diesel and the diesel always got better mileage.14.8mpg loaded like that is insane to me,My brothers 4x4 f150 don't even get that unloaded highway and its bone stock.As far as fuel prices for a long time here diesel was more then gas but now its a few cents cheaper,But if i go to a truck stop here diesel is even cheaper then a standard gas station.
#29 |
duplicate
#30 |
Just did a 3000 mi road trip on the Suburban in my signature with a V-pump 6BT and got 29 mpg overall hand calculated I drove no faster than 65 mph but generally 60 mph, weather was good / no head wind, A/C was used minimally and tires were pumped up to 80 psi. All these factors added up to this insanely high fuel economy. I do know that if I drove the 80 mph speed limit, my numbers would have been much lower, probably less than 18 mpg.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#31 |
29mpg in basicly a brick on wheels is insane to me.
#32 |
60-65 mph speeds were a major factor lol
#33 |
![]() Join Date: Jun 2016
The double overdrive doesn't hurt either. What RPM are you turning?
I'd absolutely do a diesel swap again and I'm trying to decide what I want to do in the R30. I want to shy away from a 6bt and do something different (like I did with the 6.5 into my Jeep) because there are so many Cummins swaps, but it is hard to beat the power and reliability of an old mechanical injected Cummins. My Jeep got 12-13 mpg stock. I now get 21-22 through daily commute and I can pull 24 on the highway at 75mph, plus I have tons more power.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#34 | |
