Old 06-11-2017, 10:08 PM   #1
44SAA
Door Jamb Switch?
So what's the install trick preventing the wire to not twist and break?
44SAA is offline   Reply With Quote
Old 06-12-2017, 12:51 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Door Jamb Switch?
before I put mine in I spun the switch ccw about 6 rounds then when you screw it in the wire unwinds back to normal untwisted..
Old 06-12-2017, 07:33 AM   #3
44SAA
Ha, got it. Curious did you have a single white wire only?
Old 06-12-2017, 01:12 PM   #4
Jeepwm69
I removed the trim panel and cut a hole with a hole saw behind it. Then installed the new switch and then attached the wire.
My wire had fallen down into the panel before I started so I cut the hole to fish it out. Made the job much easier and the hole is completely covered/ invisible with the trim panel in place.
Jeepwm69 is offline   Reply With Quote
Old 06-12-2017, 01:48 PM   #5
mongocanfly
The switch is nothing but a ground..only one wire to it...opening the door completes the circuit to ground..hot goes directly to the light..
No trim panels on my truck..
Old 06-13-2017, 10:32 AM   #6
TKCR
TKCR's Avatar
I had the same repair to do with both switches. Mine had rusted on the back of the switches and the wire had fallen, I was able to fish them out without cutting holes. I also just did the twist thing with the wire, and then they untwisted with the installation of the switch.
