Old 04-10-2004, 08:53 AM   #1
FrankHoy
FrankHoy's Avatar
Question disk brakes not power?!?
I got a suprise today, working on my 71. I noticed that it has disk brakes on the front but does not have a power booster. I had purchased the truck at night, so never looked very close at the brakes before. They have always worked but definitely NOT power. I had just assumed it was all drum due to not having a booster. I believed this to be an all original unmolested truck, excluding a different bad paint job. I have a couple questions, hopefully some of the brake experts can help with.
First off, is this common or did this even come from the factory like this? My option sheet on the glovebox doesn't mention anything on for brake option?
If this did come from the factory like this, can I just add a power booster? I do have a couple extra, complete with master cylinder. Would anything else need to be changed?
Any insight greatly appreciated!
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 04-10-2004, 11:02 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can just put on a power booster but, make sure you have the booster brake rod and not the manual rod .... If I am wrong some one pleease correct me..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-10-2004, 11:49 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Since discs require a higher line pressure than drums, there is normally a proportioning valve. Does your truck have one? If not, I would guess the discs were installed by a PO, and you may want to install one with the booster.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-10-2004, 12:20 PM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
Unless it's really hard to stop the truck without a booster, I'd just leave it alone. I'm running a late model master cylinder with no booster and disc brakes up front and it stops just fine without excess pedal effort.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-10-2004, 01:13 PM   #5
dinnut
dinnut's Avatar
all 71-72s had disc brakes. not all of them had power brakes though. my 72 doesnt have power brakes. to convert to power brakes you need the booster, the bracket, and the rod.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 04-10-2004, 01:50 PM   #6
FrankHoy
FrankHoy's Avatar
My truck does have the proportioning valve. The brakes work and it does stop but with alot more foot pressure, compared to my 72 with power brakes.
I am using my 71 to teach my oldest son to drive right now and he has a little more trouble, than me, with the manual brakes, being he's fairly short and lightweight. I think I may end up letting him have it for his first vehicle. He really seems to like it and keeps hinting that he wants it. That's why I would like to add the power boost, if that is all it really needs.
Are the pedal arms different, as with some cars? I can't really tell comparing my 72 to the 71. It has a different rubber pad but I think that is just because it is a Cheyenne and the 71 is a Custom.
00 Blazer
Old 04-10-2004, 02:01 PM   #7
71-longbed
Its Magically Delicious
71-longbed's Avatar
i have manual brake in my 71 ..... it took me a few weeks to get use to the added pressure i needed to apply .... if anything i think i would help your son learn how to leave plenty of room between cars when slowing to a stop ... thats never a bad thing to learn early on .... im told i tailgate ... and i dont even realize it... old habit i guess
good luck
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 04-10-2004, 07:27 PM   #8
Sweet72
Sweet72's Avatar
I thought disc brakes were optional in 71 and standard in 72. My 72 GMC C1500 originally had manual disc brakes.
Can someone please set the record straight?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-10-2004, 08:25 PM   #9
acloco
Yours should already have the proportioning valve for disc & drum. Just add booster.....and the correct length of rod for the pedal...some are the same...some are not....depends on the booster.
I have a 65 Chevelle SS with power drums...everything is new or rebuilt...still has the original shoes on it all the way around...and it stops on a dime.....if you have never driven a power drum...it is like driving a power disc brake car for the first time.
Go with the power disc brakes.....
acloco is offline   Reply With Quote
Old 04-11-2004, 03:52 PM   #10
Baradium
Binder Rep
Baradium's Avatar
71 and 72 had standard disc brakes on the 2wds.
IIRC 4x4 axles still had drum fronts, at least in the heavier trucks. I seem to remember there were no provisions for a dana 44 disc braked front end until a few years later.
'70 and before there weren't any discs on the pickups.
Clear enough?
Baradium is offline   Reply With Quote
Old 04-11-2004, 04:08 PM   #11
lukecp
Formerly yellow72custom
lukecp's Avatar
One of my friends had a '76 C10 with manual disc brakes, and PS suprisingly.
I kinda like manual brakes. You have to push a little harder, but it is a bit more fun, lol.
'71 up 4x4's also had disc brakes up front
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-11-2004, 04:15 PM   #12
krue
Designated A-hole!
krue's Avatar
The pedal arm should be the same whether you have power, manual disc or drums.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-11-2004, 08:37 PM   #13
Rod
Power brakes became standard equipment on 3/4 and 1 tons in 71... but 1/2 tons it was still an option all years.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-12-2004, 03:23 PM   #14
jorgensensc
jorgensensc's Avatar
My '72 cheyennesuper had manual disc brakes. I swapped those out for power as soon as possible.
Manual is o.k., until you really need to stop and can't lock up the brakes, even when standing on the brake pedal
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-12-2004, 11:59 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Why would you want to lock up the brakes?
I prefer the non power myself, you get a better feel, you can run bigger cams, less things to brake, and no "OH SH*T" feelings when you lose vacume for one reason or another and have to hit the woah pedal.
Old 04-13-2004, 02:25 AM   #16
Sweet72
Sweet72's Avatar
[QUOTE]Originally posted by Longhorn Man
I prefer the non power myself, you can run bigger cams
I like your thinkin Longhorn Man!
Old 04-13-2004, 02:05 PM   #17
jorgensensc
I only say lock up the brakes because when I'm in an emergency situation I like to lock the brakes then back off. Sounds crazy I know, but it lets me know I am applying the most pressure. When my brakes don't lock up, I spend precious seconds trying to figure out ifI'm going to stop, and if my brakes are working!
If that makes any sense. Maybe I'm strange.
Old 04-13-2004, 02:12 PM   #18
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
LMC truck mag states that all Chevy trucks went to front disk brakes in 1971. That means that no 1971 trucks were built with front drum brakes. My 1971 truck has disk brakes in front.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 04-13-2004, 02:22 PM   #19
FrankHoy
FrankHoy's Avatar
Don't believe everything in the LMC catalogs. Although they are great for reference.
I know that there are 71 & up trucks with all drum brakes. It may have been a special order thing. There were and are still a lot of old schoool drivers that refuse to anything but drum brakes.
00 Blazer
