#26 |
![]() Join Date: Jul 2015
Re: 350 crate engine intake and carb possible for $3,000?
Will the factory exhaust manifolds work with the vortec. And does it have drilled dipstick holes on both sides? ?
#27 | |
.. 1st yes. I'd port match the exhaust manifold to the vortec head ports.. 2nd.. I'm almost sure it's on the side all late 70's up are.. I'll look at my engine it's on the stand.. tomorrow.. |
#28 |
vortec motors had on passenger side only.
#29 |
My daughter upped my spending limit to $4000, with that I'll need to include a dual exhaust. I did my exhaust for around $300. If I do a similar exhaust that will leave me $3700 but I'll need to get everything with it, intake, carb, waterpump, etc. any suggestions? She wants it to be strong and sound mean.
http://smg.photobucket.com/albums/v655/aaronhero/ |
#30 | |
![]() Join Date: Jan 2001
#31 |
I looked one up and from what I read to use in in a non computer controlled truck I would need to replace the cam. Unless I'm reading it wrong?
https://m.summitracing.com/parts/nal-12530283
#32 |
Maybe I'm looking at the wrong engine?
#33 |
You don't need to replace the cam. I'm replacing mine because the block I have happens to be drilled for a mechanical fuel pump, but most of them aren't. That just means you need to run an electric fuel pump (and probably a pressure regulator).
The stock cam will make plenty of torque and horsepower with a carburetor (I like Quadrajets) and HEI ingition. I'm running rams horns (2 1/2 inch Dorman) exhaust manifolds on mine because I got tired of messing with the headers. |
#34 | |
Romans 10:9 - The Truth |
#35 |
No need to change the cam.. no need to change anything!!!!!!!!!!!!!!!!!
bolt on a carb intake. plumb in an electric fuel pump put a melonized gear on your distributor.. and a water pump, and your brackets and p/steer pump , alt, and start it.. |
#36 |
Do you know if the block has the clutch lever mount for a four speed? Been trying to get through to summits tech support all morning but it's been busy. Also wondering if I'll have any issues with the flywheel and if it takes a different starter than a regular 350? Will the ram horn exhaust manifolds from the 307 fit? Thanks!
http://smg.photobucket.com/albums/v655/aaronhero/ Last edited by AirSpeed; 03-06-2017 at 01:34 PM. |
#37 |
#38 |
Don't look at the exhaust tips! We cut those later and put on some stainless tips.
#39 |
JEGS has a new crate gm motor free shipping $1500.00
http://www.jegs.com/i/Chevrolet-Perf...67353/10002/-1 Check it out. |
#40 | |
#41 |
#42 |
Yea! I gave her the truck, that was as far as my generosity goes! And thanks!
#43 |
![]() Join Date: Nov 2015
Looks great and I am seriously considering that same engine. Can you share the link where you got it for $2400? Thanks!
#44 |
Just checked with my daughter, I was way off, she actually paid $2900 at Pace Performance
#45 |
video of my daughters first drive with new engine
Can't seem to get it to show up!
http://smg.photobucket.com/albums/v655/aaronhero/ Last edited by AirSpeed; 06-13-2017 at 09:06 AM. Reason: Video |
#46 |
![]() Join Date: Oct 2016
Good info
72 White Cheyenne, The Ghost |
