Old 06-13-2017, 11:10 PM   #12
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: C20 17.5 wheels and disk brakes...
that would be great, thank you. So, a 2008 would be lug centric but same bc, if I'm not mistaken - with slightly different (metric) studs(?) Any details on the swap you're thinking about or are you just using the 2008 as a basis for comparison for caliper interference?
Yes they are lug centric but same bolt pattern. The swap uses 2003 and up chevy 2500 parts and I wanted to make sure the old wheels would clear the caliper before purchasing.
Here is the link to the bracket kit for the swap.
http://www.thehollisterroadcompany.c...converion.html
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
17.5, c20, disk brakes
