Old 06-13-2017, 03:45 PM   #1476
MIKESAD50
Re: My 52 GMC Build
Congratulations on the awards.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 06-13-2017, 11:43 PM   #1477
joedoh
joedoh's Avatar
Re: My 52 GMC Build
thanks for the pics!
Old 06-14-2017, 12:42 AM   #1478
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by oldman3 View Post
Congrats on the wins, and thanks for sharing the pics...Jim
Thanks Jim lots of really nice rides there.
Originally Posted by Dieselwrencher View Post
Congrats on the awards! That has to make you feel pretty good!
Thanks I am honestly blown away. I guess I did something right.
Thanks it's nice to see other people like what I have built.
I love seeing the personality that comes out in a vehicle that someone has built.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-14-2017, 12:50 AM   #1479
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So the brown truck showed up today with my upgraded transmission controller. Going from the Quick 1 to the Quick 4. Tons more options for setting up the shift points, pressures and firmness per gear. It will also hold 4 different shift patterns and can detect trans slip. I will set up to my liking "normal", "trailer", "burnout" and "dragrace". I hope to get it plugged in and set up next week, it uses the plugs I already have.
1951 MG TD
Old 06-14-2017, 05:19 PM   #1480
rusty76
rusty76's Avatar
Re: My 52 GMC Build
That's really cool you can set your trans up like that.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-15-2017, 04:30 PM   #1481
piratexpress1369a
piratexpress1369a's Avatar
Re: My 52 GMC Build
Great for the boys on the award
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 06-15-2017, 11:05 PM   #1482
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya if anything bugs you about an auto you can change it. I can even make it a manual shift.
They both cleaned up the Jimmy, so it's great they got an award.
1951 MG TD
Old 06-15-2017, 11:22 PM   #1483
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So some big news at my house.... I'm building a shop in my back yard. Just a little 30X40 with heat and hydro and a 4 post hoist. I'm so excited I have never had a heated play house before. Construction should start around the end of July.
Something like this.
Name:  Storage space.jpg
1951 MG TD
Old 06-16-2017, 02:36 AM   #1484
Nut Case
Nut Case's Avatar
Re: My 52 GMC Build
Lowered
I'm in the middle of building my 28 X 40 shed with hydronic radiant in the floor, using a 50 gal hot water heater. Still working on the details
Do the research on what to do for hydronic heating for your area I guaranty if done correctly, you'll wonder how you lived without it.
I've done this before: 6 mil visqueen, 2" Styrofoam, 4" expansion joint for the perimeter, net wire fence (it's cheaper), to zip tie the tube to the netting (I'm going 8" on centers, with no run longer that 300") then the concrete, I recommend 6 bag mix to lesson the cracking. Stricke the concrete don't saw cut!!! up front costs is twice the cost of other heating systems but much cheaper to run. No more cold floors, and work when it is below 0, coldest I have experienced is -20. I know in the states we don't know the cold that you folks have in your neighborhood.
I'm running on, PM if you have any other questions. Your truck is fandamtastic.
Strong work.
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-17-2017, 06:35 PM   #1485
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Lower congrats on the shop build! Looking forward to the updates.
Advanced Design is offline   Reply With Quote
Old 06-18-2017, 07:47 AM   #1486
rusty76
rusty76's Avatar
Re: My 52 GMC Build
I'd love to have a space to work in. More than just truck stuff that is for sure.
My build thread
Crossmembers CC
Old 06-18-2017, 09:51 AM   #1487
piratexpress1369a
Re: My 52 GMC Build
That's awesome..do you have to take down your garage first for accessibility to the back yard
63
Old 06-19-2017, 07:56 PM   #1488
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by Nut Case View Post
Lowered
Strong work.
Keep on keepin on
NC
Thanks NC. I am planing on in floor heat, my brother put it in his shop.
Thanks I'm real excited.
Oh it will end up being a hang out spot as well.
No I am cutting the back wall out to make garage a drive though. Then putting barn doors on both sides.
Construction is planned to start end of July.
1951 MG TD
Old 06-19-2017, 08:36 PM   #1489
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So Fathers day turned out great. I took my dads car and my truck to a "Classics against Cancer" fundraiser. We lined up with 7 friends rides and made a day of it. It was the perfect fundraiser to bring my dads car too.
1st all our rides
2nd this chev was on a F350 chassis a drive train on air with my same motor and dually
3rd A very nice blown '34
4th I believe a '64?
5th you don't see Delorean's very often.
1951 MG TD
Old 06-19-2017, 08:58 PM   #1490
lower50's
lower50's's Avatar
Re: My 52 GMC Build
1 Our friend won peoples choice with her dads '57 BelAir
2 I won Most Radical with my truck
3 How of you have seen inside a Delorean
4 A pic of the rear air bags of the F350 chev, they are off a transport and runs them at 10psi
1951 MG TD
Old 06-19-2017, 09:07 PM   #1491
OutlawDrifter
Re: My 52 GMC Build
Very cool, thanks for sharing! Great job on the "Most Radical".
I see he has a 12v flux capacitor, much less energy to run than 1.6 gigawatts!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 06-19-2017, 11:13 PM   #1492
oldman3
oldman3's Avatar
Re: My 52 GMC Build
Lower, congrats on the win, and for sharing the pics...Jim
oldman3 is offline   Reply With Quote
Old 06-19-2017, 11:28 PM   #1493
joedoh
joedoh's Avatar
Re: My 52 GMC Build
those bags look like they would move a house.
Old 06-20-2017, 08:26 AM   #1494
Desert1957
Desert1957's Avatar
Re: My 52 GMC Build
Attachment 1661617
Congrats on the garage, I personally am into garages. Sure make the gearhead life easier.
Desert
Desert1957 is offline   Reply With Quote
Old 06-20-2017, 03:08 PM   #1495
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks man. The 12v flux capacitor is probably cheaper to buy as well lol
Thanks Jim I am amazed every time I win something
Yes I wonder what they are rated at?
I agree, can't wait for construction to start.
1951 MG TD
Old 06-20-2017, 03:14 PM   #1496
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So this Saturday I'll be entering my first burn out contest. I got my used tires mounted today from my sponsor shop Woodside tire in Kitchener. I just have to get them on the truck. I also got my upgraded trans controller hooked up and I'll program tomorrow.
1951 MG TD
Old 06-20-2017, 05:52 PM   #1497
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Have fun and enjoy it! Congrats on the award with your truck too! The new trans controller sounds killer. I have a 95 F350 with a 7.3 and when it dies it's getting a 6 cylinder. It would be cool to use the E40D but I don't know if I will or not. The adapters are still big money.
Ryan
1969 Chevy milk truck
Old 06-20-2017, 11:20 PM   #1498
oldman3
oldman3's Avatar
Re: My 52 GMC Build
Ready for the smoke...Jim
Old 06-21-2017, 06:18 PM   #1499
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya making some stuff work together can be real tricky or expensive sometimes.
They give 30 seconds.
1951 MG TD
Old 06-21-2017, 06:22 PM   #1500
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Went out and programmed the trans today. Wow this thing can do a ton.
1951 MG TD
bagged, build, diesel, gmc, hot rod
