Old 06-13-2017, 10:43 PM   #1
BigDan3131
BigDan3131's Avatar
Question Air Flow
First off, please don't tell me to stick a mechanical fan and shroud back on...With that said large single 16" with shroud electric or dual 12" with shroud for 500HP. No AC but will have both trans and oil coolers in front of it. Lets amend that and say AC in the future if I decide to go on Anti Tour.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 06-14-2017, 07:13 AM   #2
corvettejim1968
corvettejim1968's Avatar
Re: Air Flow
I went with a single large fan. very high speed. bought it at so-cal
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 06-14-2017, 09:39 AM   #3
scoot_mcgrute
Re: Air Flow
I'm running a dual 12" setup with my aluminum radiator for my LS swap. The fans were wired up so I have one coming on regularly and the other one comes on if the temp warrants it.
I do have a manual but I have no problems keeping my setup cool with the single 12" fan so I would think you would be good either way.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 06-14-2017, 11:41 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Air Flow
What is the heart-ache with the "Clutch" fan and shroud?
Old 06-14-2017, 12:14 PM   #5
LVPhotos
LVPhotos's Avatar
Re: Air Flow
http://67-72chevytrucks.com/vboard/s...d.php?t=699937
Flex-a-lite black magic 3300 cfm post #14
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-16-2017, 03:36 AM   #6
BigDan3131
BigDan3131's Avatar
Re: Air Flow
Well, the issue with the mechanical fan is shown quite well on Motor Trend [Engine Masters Series] where the take a mild 350 and mount the various fans with shrouds to see how much power they eat.
Old 06-16-2017, 09:45 AM   #7
The Rocknrod
Moderator
Re: Air Flow
What number on "the list" are you on Street Outlaws.
Old 06-16-2017, 10:02 AM   #8
geezer#99
geezer#99's Avatar
Re: Air Flow
Interesting test but did you notice how little difference in hp there was at the rpm you'll be doing your normal driving. Down at 2500 rpm or less.
And if they had let the clutch fan heat up like it would normally I'd bet it wouldn't consume hardly any hp. Not that you'd feel in your butt!
And how much power does your big electric consume. LIkely the same at that rpm.
And if your big electric fan can't keep it cool and your temp climbs you'd see a bigger hp loss.
Electric might be superior at 5000 rpm but how often do you run there.
Old 06-16-2017, 05:15 PM   #9
WOLFMANmike
WOLFMANmike's Avatar
Re: Air Flow
well said !
WOLFMANmike is offline   Reply With Quote
Old 06-16-2017, 09:23 PM   #10
lumpy63
lumpy63's Avatar
Re: Air Flow
Thanks Rocknrod.... beer thru the nose on that one
lumpy63 is offline   Reply With Quote
