![]() Join Date: Feb 2004
Dome light clips.... help?
Ok so i went to install my new dome light on my build and found two huge holes for the screws. I assume there is some type of cage nut or clip that retains the screw. I have tried buying several j type clips with no avail....does anyone know what the clips should look like or where to get them. Or is there some other method of attachment im missing. The cab was stripped when I got it....
Thanks again Rob....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
The Older Generation
Re: Dome light clips.... help?
I haven't used one of the replacement light assemblies but the originals had two plastic clips molded into the back and just snapped into the holes. When you try to remove the original housings the plastic clips almost always break off. LockDoc
![]() Join Date: May 2006
Both of my clips broke - so I just used zip ties and it worked great!
Curtis - Berea, KY 1969 1/2 ton 2WD CST 1971 1/2 ton 2WD Shortbed 1977 Mercedes 450SL 1966 International Scout |
Oh my, now i feel like an idiot.....Lol i assumed because there were holes in there that it must have screws to hold it in place! I bet when i get home i can snap it right in! Thanks guy's!
#5 | |
![]() LockDoc
