Old 06-15-2017, 03:51 PM   #1
Hypertrophy
Is this normal (Pic)
Is it normal to have visible splindles on the driveshaft showing where it connects at the carrier bearing?
1968 GMC 2500
Thanks!!!
Hypertrophy is offline   Reply With Quote
Old 06-15-2017, 04:21 PM   #2
toolboxchev
Re: Is this normal (Pic)
Might help to know whether it is an automatic or 3,4 speed truck. I think my automatic shows the splines yet not that deep into the carrier bearing.
Are you having any drivetrain issues?
toolboxchev is offline   Reply With Quote
Old 06-15-2017, 04:26 PM   #3
mike1971c10
mike1971c10's Avatar
I think we are looking at a slip joint. It moves in and out for the rear end to flex (or back and forth)
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 06-15-2017, 04:29 PM   #4
Hypertrophy
It's a 400 Turbo. 3 speed Automatic. I installed a 454 with a 400 Turbo attached to it. I removed a 383 Stroker with a 400 Turbo attached to it. The tail shaft of the new engine/trans slide right in. Then when I went underneath to tighten everything I saw the spindles showing. Of course I don't remember if they were showing when I removed old engine/trans. No previous drivetrain issues...but I wanted to make sure I didn't cause this installing new combo, which seems nearly impossible because it's bolted/fixed position at both ends.
Old 06-15-2017, 06:01 PM   #5
toolboxchev
Here is a SBC behind a Turbo 350 in the foward engine position with a 2wd truck. There is a set of bolt holes in most frames for the 4wd trucks for the engine mounting location.
Hope this helps, stock drive lines also!
Old 06-15-2017, 06:23 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... perfectly normal.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-15-2017, 06:34 PM   #7
Hypertrophy
Thanks so much guys! Y'all rock. Time to get on with the Big Block Build.
