Closed Thread
Old 06-14-2017, 11:02 PM   #5451
ghalperin
ghalperin's Avatar
Re: What did you do to your truck today? Chapter II
Went for my first road test since my frame off.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 06-14-2017, 11:04 PM   #5452
mud.man.rj
mud.man.rj's Avatar
Sooo how was the 1st run in the truck, bet it was nice to get out in it again.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 06-14-2017, 11:42 PM   #5453
ghalperin
ghalperin's Avatar
Mudman.
I was so stoked to get it back on the road. I last drove it 44 days ago.
I upgraded so many systems. The power steering was great. The disk brakes acted as they should. The lowered height, with Bilsteins and sway bars made it handle really well. The full syncro trans (still on the column) was nice to use. The 2:76 rear end was such an improvement over the 4:11s that were in it. Although it kicked my butt twice, the Centerforce clutch works perfect. Last but not least, the 396 runs really well. I fried the tires a couple of times. It has a lot of power.
I've got a ways to go still.
Glenn
Old 06-15-2017, 01:05 AM   #5454
In The Ten Ring
Yesterday I got my original 4 row (lower) radiator brackets sand blasted. A friend from jr. high I haven't seen since 1998 did that for me at this shop. Great seeing him again and getting that done.
In The Ten Ring is offline
Old 06-15-2017, 02:51 PM   #5455
creekncabin
Replaced the old "3 Wire" Alternator with a new "1 Wire" Alternator.
Quick and painless....
creekncabin is offline
Old 06-15-2017, 07:20 PM   #5456
Boog
laying low
Boog's Avatar
[QUOTE=ghalperin;7967753]Went for my first road test since my frame off.
Attachment 1661379
As my friend says "that's cool beans right there".
Good looking driver.
Your truck makes me wish I still had the 3ott in mine.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 06-15-2017, 11:19 PM   #5457
butler57
butler57's Avatar
Broke a fan belt on my way back from the hardware store. Had my wife pick me up, quick trip to the auto store, 15 mins to put on a new belt. Gotta love working with old trucks.
'72 Highlander
'88 GMC Sierra 1500
'14 Chevy Silverado 2500HD Duramax
butler57 is offline
Old 06-15-2017, 11:24 PM   #5458
mud.man.rj
mud.man.rj's Avatar
Your sure right on the belt and old classics, try that on any new vehicle, lucky to see where the belt even goes.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 06-16-2017, 01:13 AM   #5459
mike16
I installed two valve cover gaskets, a fuel pump and some new fuel hoses and an inline filter,
I got rust in the tank problems.
Discovered a vaccuum line leak between the carb and the vaccuum advance.
mike16 is offline
Old 06-16-2017, 02:04 AM   #5460
In The Ten Ring
I got a little something done yesterday (posting at 2 AM). I put NAPA Rust Treatment onto my lower radiator brackets as a primer.
Old 06-16-2017, 10:02 AM   #5461
butler57
butler57's Avatar
Mudman.
I'm no mechanic but I really do enjoy puttering around and fixing things up. I love how easy these trucks are to work on and I really enjoy all the help I've received on this site.
'72 Highlander
'88 GMC Sierra 1500
butler57 is offline
Old 06-16-2017, 01:59 PM   #5462
B Myers
B Myers's Avatar
I did the same when I restored my '71, found out the original wiring could not carry the robust charging capability of the one-wire alternator. The factory fuse link or if you replace it with an inline fuse may not handle the potential 60 amps or so that it can generate so I added into the harness a 10 guage wire direct from the alternator to the battery. Great add though for these old trucks even though it knocks out the generator guage function. May deal with a voltage guage in it's place at a later date.
B Myers is offline
Old 06-16-2017, 09:05 PM   #5463
Towbiz
Picked up my freshly upholstered buddy seat , dug out tach dash . Now to install tilt column & power steering . Soon !
Towbiz is offline
Old 06-17-2017, 01:57 PM   #5464
ghalperin
ghalperin's Avatar
I went to Donut Derelect's and then Home Depot.
Glenn
Old 06-17-2017, 04:30 PM   #5465
ghalperin
ghalperin's Avatar
Attachment 1661966
Attachment 1661967
Glenn
Old 06-17-2017, 10:39 PM   #5466
GoaterAz
GoaterAz's Avatar
Picked up the wheels from powder coat and got the tires mounted.
15x6 225/70/15 BFG Radial T/A
15x8 275/60/15 Nitto 555r
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline
Old 06-17-2017, 10:51 PM   #5467
70cst
70cst's Avatar
I brought my truck home ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 06-18-2017, 02:55 AM   #5468
mike16
gave my front end a lube job
noticed that my disc brake pads need replacing
tommarrow i'm going to flush my cooling system
mike16 is offline
Old 06-18-2017, 04:18 AM   #5469
In The Ten Ring
Yesterday I got my 4 row lower radiator brackets painted. That should do it for front-end reassembly preparations.
Old 06-18-2017, 12:24 PM   #5470
chewychevy67
I added a tailgate lock.
chewychevy67 is offline
Old 06-18-2017, 08:14 PM   #5471
66clow
66clow's Avatar
[QUOTE=ghalperin;7969613]I went to Donut Derelect's
Left LA in January, miss that get together. Awsome looking tuck!
Went to pick up some yummy southern barbeque for fathers day. But usually run into this traffic on the weekend in the middle of the day. Joys and pain of living on the beach, but who is complaining, I moved here from LA. This is nothing. Did a little work Saturday on the roof surface rust repair. Also went to a car show but just saw a bunch of new mustangs and corvettes. Not much of a show, passed a bunch of those on the way there. Lol Happy Fathers Day all!
66clow is offline
Old 06-18-2017, 10:09 PM   #5472
Possmguts
Possmguts's Avatar
Took the bed back off the frame and took it apart and put the new sides on and sat it back on the frame today. Will finish mocking it all up tomorrow...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 06-19-2017, 12:07 AM   #5473
toolboxchev
Got into the front end today, man if you do not have an oxy torch its a pain. I torched off those upper ball joints in less than 5 min. flat. Then onto the stuck lower ball joint. Red hot on the ball joint stud then hit with the hose, 3 times over. Ball joint removal tool and a punch it fell right out.
Having the right stuff is a blessing.
toolboxchev is offline
Old 06-19-2017, 12:08 AM   #5474
ghalperin
ghalperin's Avatar
I put my front bumper and inner fender wells back on.
Glenn
Old 06-19-2017, 02:45 PM   #5475
DarkFlounder
Finished the ignition portion of my maintenance binge. Pulled the distributor, replaced the points, condenser, cap and rotor (plugs, wires and coil were replaced a few weekends ago).
As much as I love the SBC, there are times when I think Ford had the right idea. Full-size truck with a 4" lift, getting to the distributor is a real chore as an older fat guy. Turned a two hour job into several hours across two days.
Adjusted timing and dwell, the beast purrs like a happy beast now.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Closed Thread
