Before and After
Amount of oil in rear end.
Just a quick question, how much oil (approx) will it take to fill a 12 bolt diff with 3.73:1 posi in it?
I have the rear end out and I would like to fill it from the diff cover.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
I think its like 2 quarts, but thats a guess, I know I fill it till it gets to the plug hole, and it seems like it takes almost 2 of the tall skinny bottles that 90 weight comes in.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
Do yourself a favor and get one of those cheap thumb pumps for putting gearlube in outdrives on boats. There at wally world for 5 bucks. Much easier than squeezing those tall skinny quarts.
It sounds like you have the differential out and turned with the cover up. 3 1/2 pints will fill the rear end so that when you check it installed, the lube will be at the plug line where it should be.
Jim |
its all about the +6 inches
Don't forget the posi additive.
