Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-18-2017, 09:01 PM   #26
04ls1gto
Re: Project Money green
New rear panels
04ls1gto is offline   Reply With Quote
Old 06-18-2017, 09:56 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
Looks really good! That first drive is always a bit of a rush and no problems is icing on the cake...
LockDoc
Leon
Old 06-19-2017, 07:39 AM   #28
nastety92
Looking good. What did you make them out of?
Nick
nastety92 is offline   Reply With Quote
Old 06-19-2017, 12:48 PM   #29
04ls1gto
Nick
Had some 1/4" luan at the shop so I cut that to fit tight and covered it in pleather
Old 06-19-2017, 02:12 PM   #30
nastety92
Nice job. Did you also get the seats all mounted? I'm interested to see how you secured down the front seats.
What else is left to get that thing road worthy?
Nick
Old 06-19-2017, 08:59 PM   #31
04ls1gto
Front and middle seats are mounted. Been driving it for a few weeks and it runs great, CPP disks work great it's like driving a new truck. Hopefully replacement springs will be here this week. Giving the interior some love now, headliner, new door panels, fat mat and new window felt to stop them from rattling
Old 06-19-2017, 09:02 PM   #32
04ls1gto
Rear mounts from second row
Old 06-20-2017, 07:25 AM   #33
nastety92
Looks great man. Glad it's on the road and running good. What did you use to mount the front seats and how did you anchor them down?
Nick
Old 06-20-2017, 08:36 AM   #34
04ls1gto
Nick
Had to make a few spacers out of some box tubing and bolted it through floor with grade 8 hardware and fender washers. Fronts were fairly simple to install
Old 07-02-2017, 04:06 PM   #35
04ls1gto
The correct springs and shocks showed up Saturday so I swapped them out this morning. Went from CPP 5" rear springs to 4" HD and it sits level and rides much better. My brakes started to make noise so I'll have to investigate that.
Old 07-02-2017, 09:35 PM   #36
LockDoc
LockDoc's Avatar
Never ends does it...... Stance looks good!
LockDoc
Leon
Old 07-02-2017, 10:07 PM   #37
04ls1gto
LockDoc
Never ends, brakes only have 250 or so miles on them and only easy use. I cleaned the brake dust out of the rear slots/ drilled holes. Gonna try cleaning the fronts to see if it fixes the noise
Old 07-02-2017, 10:10 PM   #38
04ls1gto
Wife took some great pics after we went for ice cream
Old 07-09-2017, 01:07 PM   #39
Advanced Design
Advanced Design's Avatar
Coming out very nice. Great looking Burb!
Advanced Design is offline   Reply With Quote
Old 07-09-2017, 04:22 PM   #40
04ls1gto
Thanks, took it on it's first highway adventure today. Would be really nice to have another gear as 60mph is about all she's got. I am going to start planning my LS swap for this upcoming winter. Thinking of a L92/ 4l80e combo, the junkyard I got my seats at has a few of them for decent price
Old 10-09-2017, 05:11 PM   #41
04ls1gto
Been getting a clunking sound from under the passenger floor so I went to shop today to fix. Found out body mount was toast, removed mount and cut and welded in a patch. I'll get it put in one night this week.
Old 10-09-2017, 05:21 PM   #42
04ls1gto
In the "paint booth"
Old 10-10-2017, 07:52 AM   #43
nastety92
Truck looks great, keep up the good work.
Old 10-10-2017, 11:58 AM   #44
Advanced Design
Nice fix on the body mount.
Old 10-10-2017, 02:37 PM   #45
youngrodder
youngrodder's Avatar
That should quiet it down...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 10-10-2017, 07:32 PM   #46
04ls1gto
Thanks, unfortunately I have practice. I fixed the two rear one's this way when I replaced the plywood floor
Old 10-10-2017, 07:35 PM   #47
04ls1gto
Marc
I hope so it's driving my OCD nuts. I swapped the mirrors for some sport ones and when I look at the truck all I can see is the holes that need to get patched and body worked
Old 10-15-2017, 06:20 PM   #48
04ls1gto
Got the body mount painted and installed today. Also prepped and painted the rest of the pass side frame rail.
Old 11-23-2017, 10:21 AM   #49
04ls1gto
Christmas came early for the suburban. Picked up a 2014 l96 6.0 out of a 2500 pickup and 2wd 6l90 trans to go with it. Engine is really clean and has 34k mile on it. Tranny has 21k miles on it. Gonna upgrade cam and ditch vvt and DOD before it goes.
Old 01-01-2018, 09:18 PM   #50
04ls1gto
Been working for the past few weeks to get cam swap done. Ended up doing new head gaskets and arp bolts. Ls2 timing chain and cover. GM hot rod oil pan and comp cam trunion upgrade. Now that engine was back together I dove into truck this morning and made killer progress.
Started at 7 and had all the sheet metal off and engine trans out by 1. Old greasy 350/3 speed next to new 6.0/6l90 setup
