Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-18-2017, 11:24 PM   #1
dooce
Looking at a GMC 7000- Help identify?
Im going to go look at a 1986 GMC 7000 later in the week. The guy sent me pictures earlier and says its a 454/5 speed manual. Most of these trucks I see are 366/4 speed, did these ever come with the 454 and a 5 speed? If so, is the 5th gear OD?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 06-19-2017, 01:24 PM   #2
Bob B.
Re: Looking at a GMC 7000- Help identify?
A 454 was optional in the medium duty trucks '79 to '81, so if it's an '86 I would say it is not the original engine. Should be a 366 or 427, SPID label should say. As for transmission, it's most likely a Clark 285V, which is direct in 5th.. There were many 5 speed manual transmissions available in those trucks, a couple were overdrive (Clark 285VO one of them), so again check the SPID label.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-19-2017, 10:09 PM   #3
sweetk30
sweetk30's Avatar
the air cleaners for some reason say 7.4l / 454 on them . but there 366 or 427 tall deck .
waterpump area on block is flat across on std deck reg bbc motors . pic 1
then tall deck motors are taller head surface = more meat above the block . pic 2 .
i dont recall this vintage with o.d. gear . i have a 88 gmc7000 with the 366/5 speed and its just 1:1 in 5th .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
