Closed Thread
Old 06-19-2017, 02:46 PM   #5476
DarkFlounder
Re: What did you do to your truck today? Chapter II
Delete as duplicate.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 06-19-2017, 03:36 PM   #5477
NoStopN
NoStopN's Avatar
Originally Posted by toolboxchev View Post
Got into the front end today, man if you do not have an oxy torch its a pain. I torched off those upper ball joints in less than 5 min. flat. Then onto the stuck lower ball joint. Red hot on the ball joint stud then hit with the hose, 3 times over. Ball joint removal tool and a punch it fell right out.
Having the right stuff is a blessing.
Tell me about it. I tried replacing one in my work parking lot. But the lower wasn't going back in without heat & I didn't have enough.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 06-19-2017, 06:29 PM   #5478
Metaldoc
Metaldoc's Avatar
Originally Posted by ghalperin View Post
I put my front bumper and inner fender wells back on.
Attachment 1662656
You are going to enjoy not worrying about scratches or dirt scuffs. Nice job.
Metaldoc is offline
Old 06-19-2017, 07:45 PM   #5479
NoStopN
NoStopN's Avatar
Originally Posted by Possmguts View Post
Took the bed back off the frame and took it apart and put the new sides on and sat it back on the frame today. Will finish mocking it all up tomorrow...
I saw the same photos show up in my FB feed today.
NoStopN is offline
Old 06-19-2017, 09:23 PM   #5480
ghalperin
ghalperin's Avatar
Thanks, I'm a big fan of going all out on the mechanicals and leaving the body alone. If it had a few prior paint jobs it'd be a different story.
I installed my Marchal Amplilux headlights today.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 06-19-2017, 10:43 PM   #5481
VWNate1
VWNate1's Avatar
Thumbs up French (Marchall) Headlamps
Like I said about a Woman (she was no lady) I used to date : VERY nice headlamps ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-19-2017, 10:48 PM   #5482
ghalperin
ghalperin's Avatar
Re: French (Marchall) Headlamps
Thanks, I can't wait for it to get dark to see how they work. The original headlights were like old Rayovac flashlights.
Glenn
Old 06-19-2017, 10:50 PM   #5483
toolboxchev
Hey I know someone who resembles those old Rayovacs.
Same tool isnt that sharp!
toolboxchev is offline
Old 06-19-2017, 11:07 PM   #5484
VWNate1
VWNate1's Avatar
They sure look bright in post # 5495 ! .
Yellow headlamps give far less glare and further out visibility but they're quasi illegal in Cali. ~ expect some tickets .
-Nate
Geezer
VWNate1 is offline
Old 06-19-2017, 11:50 PM   #5485
ghalperin
ghalperin's Avatar
In the photo they were bright, but not so much on the road. I'll keep my fingers crossed for the coppers. I've got the Cibie H4s ready just in case.
Glenn
Old 06-20-2017, 12:56 AM   #5486
VWNate1
VWNate1's Avatar
Thumbs up French Headlamps
Cool beans .
I loved my yellow H4 headlamps but got tired of tickets and so removed them .
My then 18 year old Son put them in his Hot Rod and drove like a maniac and never got one ticket .
Go figure .
-Nate
Geezer
VWNate1 is offline
Old 06-20-2017, 12:09 PM   #5487
ChaseBBC
ChaseBBC's Avatar
Starting to put together the puzzle
ChaseBBC is offline
Old 06-20-2017, 12:16 PM   #5488
ghalperin
ghalperin's Avatar
That's the fun part.
Glenn
Old 06-20-2017, 06:49 PM   #5489
re1
re1's Avatar
Originally Posted by Towbiz View Post
Picked up my freshly upholstered buddy seat , dug out tach dash . Now to install tilt column & power steering . Soon !
Any Pictures ?
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline
Old 06-21-2017, 12:56 AM   #5490
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Knocked 45 years of grease off my 72 driver truck, and snugged up some gaskets. Dirty job, but I refuse to work under a grease pit, which was approaching 3/8" an inch in places. Greased everything up to the rear drive shaft, where I suppose either the U-joints or zerk fittings are wrong. It's not possible to put a grease gun on the zerk fittings. Can't say how to pull a drive shaft yet, but I will at some point.
The driver is having intermittent starting issues, so as part of a revamp, I tried to install a newer starter, which came off my restoration project. Both 402 trucks, so no problem right? Nope. While it may have worked, the hole in the flex cover on my 72 is taller. It doesn't appear cut, perhaps a replacement? Seems all flex covers would be the same, for BBC trucks anyway. The starter that was on there doesn't appear to check out for a 72 C20 either. All I know is it's a good Delco Remy 1109065 and fit. For what it's worth, the replacements call for the same starter, 71 C10 402 or 72 C20 402.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 06-21-2017, 07:07 AM   #5491
NoStopN
NoStopN's Avatar
Tony, I think your story exemplifies why I haven't gotten into owning an older vehicle before. My previous trucks from this era were someone else's headache & I was naive.
NoStopN is offline
Old 06-21-2017, 02:04 PM   #5492
DarkFlounder
On my '72 K2500, with the big driveshaft and U-Joints, I couldn't get my grease gun on the zerk fitting. Found a smaller fitting on an old Harbor Freight gun I had, fit my current one (Lincoln). Snug fit, but it got on there.
For REALLY tight fits, you can use a needle attachment. Press it into the zerk fitting and it'll work. Might need a second set of hands.
Old 06-21-2017, 02:06 PM   #5493
DarkFlounder
Over the weekend, did the full ignition tune-up (points/condenser/cap/rotor/wires/plugs) and even replaced the coil.
Was driving to work yesterday morning, and about a block away from the office, the engine started running a bit rough, like I was getting a misfire. Made it to the office then back home.
Frigging #4 spark plug wire came loose from the distributor cap.
Old 06-21-2017, 03:19 PM   #5494
WilliamFd55
Finished up the bumper. Have a 70 C10, wanted to do fog lights. Found a 72 bumper at a swap meet and went to work..... Added a lower valance, made some brackets for the led's and lenses. Then polished and cleared. The LED's have the option to be clear or amber to complete the "Stock" look.
WilliamFd55 is offline
Old 06-21-2017, 03:59 PM   #5495
skinnan
I added a braided power steering hose
skinnan is offline
Old 06-21-2017, 04:36 PM   #5496
ct67_72
ct67_72's Avatar
I stripped my roof back to the original white paint.
Dan.
Drivetrain parts and accessories.
68 medium green shortbed fleetside
ct67_72 is offline
Old 06-21-2017, 06:17 PM   #5497
71CHEVYSHORTBED402
Needle might work, thank you. At most there's a pinch between the zerks and I believe what's called yokes. At this point I'm willing to let it go. I need to learn how to remove this stuff on the 71 anyhow. Edit: Course I'm assuming different U-joints or zerk fittings are an option.
Tony
Old 06-21-2017, 07:43 PM   #5498
NoStopN
NoStopN's Avatar
I didn't even know anyone was making those. And now that I know they exist, I want one.
NoStopN is offline
Old 06-21-2017, 07:55 PM   #5499
ghalperin
ghalperin's Avatar
I have a NOS Smash-Hit grill guard, so I installed the outer towel bar to see how I'd like it. I snapped the photo and took it off. I think the grill guard would look better with fog and driving lights, although I think the slant nose looks best with nothing added.
Glenn
Old 06-21-2017, 08:23 PM   #5500
ghalperin
ghalperin's Avatar
Closed Thread
